* * * R O C K S P O R T G E A R * * * .....................11/22/09..... #973384 11/22/09 09:20 PM
Dave Scott Offline OP
1994-2003 KIA SPORTAGE OFF-ROAD EQUIPMENT
and local one-off fabrication for any make
4" all-coil suspension lift: $795 includes: 4 coilsprings, 2 new upper strut mounts, 2 rear shocks, 2 new sway-bar drop legs, new adjustable rear panhard rod, Grade 8 hardware
front lift: $345 includes: 2 coil springs, 2 new upper strut mounts, 2 sway-bar drop legs and grade 8 hardware
rear lift: $495 includes: 2 coil springs, 2 new rear shocks, rear adjustable panhard bar and grade 8 hardware
rear shock relocation system: $225 X-member, lower weld-on shock studs, shocks, weld-on bumpstop nubs, bumpstops, coil retainers and Grade 8 hardware
4" deluxe all-coil articulation kit: $945 includes: 4 coilsprings, 2 new upper strut mounts, 2 new sway-bar drop legs, 2 rear shocks, rear shock upper mounting crossmember, coil retainers, bumpstops, weld-on bumpstop nubs, weld-on lower shock studs, new adjustable rear panhard rod, Grade 8 hardware
front winch bumpers: $365 w/adjustable mounting height for stock, 1.5" body lift and 3" body lift. includes winch mount holes and fairlead slot, Grade 8 hardware, tow points and shackles
rock rails: $195/pr. [bolt-on or weld-on]
front second shock conversion: $165 includes shocks, shock studs, upper mounting plate and hardware [welding required]
front coils- $215/pr.
rear coils- $215/pr.
upper strut mounts- $95/pr.
rear adjustable panhard rod- $195
rear shocks- $95/pr.
sway-bar drop legs- $45/pr.
PM me for phone and/or address info.
SHIPPING CHARGES APPLY TO ALL ITEMS EXCEPT COIL SPRINGS (included in price) AND ITEMS PICKED-UP IN PERSON.
all parts painted gloss black.
warranty: all manufacturer defects will be repaired or replaced. shipping will be negotiated and if it is unreasonable to ship, local repair cost of part will be split and negotiated.
Re: * * * R O C K S P O R T G E A R * * * .....................11/22/09..... [Re: Dave Scott] #973385 12/20/09 01:47 AM
Hydra747 Offline
Re: * * * R O C K S P O R T G E A R * * * .....................11/22/09..... [Re: Hydra747] #973386 12/24/09 04:03 AM
Sportege_Panicmech Offline
Thats some serious stuff. man I wish I could buy get that bumper..
Re: * * * R O C K S P O R T G E A R * * * .....................11/22/09..... [Re: Sportege_Panicmech] #973387 11/03/10 06:02 PM
hipp1213 Offline
pm sent....... hope you are still putting these things together!
Re: * * * R O C K S P O R T G E A R * * * .....................11/22/09..... [Re: Dave Scott] #973388 08/02/11 03:05 AM
jeff115 Offline
are these lifts still available?
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6102 MB (Peak: 0.6925 MB) Data Comp: Off Server Time: 2026-05-29 15:18:19 UTC
