Couple of vacuum questions #973402 11/22/09 09:30 PM
F
frozen Offline OP
I have just about wrapped up my vac line issues but I ran into a little problem.
My truck (87 p/u 22r MT FED) has a vacuum part that doesn't appear to be listed in the 85 FSM.
It is mounted on the passenger wheel well, right next to the VSV and the vacuum switch. One of the lines goes to a tee and I can't figure out what is supposed to plug into that tee.
If anyone can identify what that mystery part is and more importantly what is supposed to plug into it I would appreciate it.
Here is the section out of the 85 FSM so you don't need to dig it out
Thanks for the help
-frozen
Re: Couple of vacuum questions [Re: frozen] #973403 11/22/09 11:49 PM
toyomorph Offline
well it's the same as my truck but I can't tell in your pic what you are pointing at that it's supposed to connect to.
canyon country explorer
1993 4x PUP
Re: Couple of vacuum questions [Re: toyomorph] #973404 11/23/09 06:32 AM
F
frozen Offline OP
Maybe this picture will be a bit clearer
I am trying to figure out what the piece with the black cylinder on one end is. It has two vac lines coming out of it. One of them (the one with the two arrows pointing to it) goes to a tee and I don't know what plugs into the tee.
Any ideas?
Thanks
-Pete
Re: Couple of vacuum questions [Re: frozen] #973405 11/23/09 07:19 AM
stock87 Offline
That's the A/C idle up systemà dunno if your truck still has it, but originally there was another diaphragm on the throttle lever that idled the motor up when the A/C kicks on. That's where the hose goes.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Couple of vacuum questions [Re: stock87] #973406 11/23/09 08:34 AM
kewlynx Offline
Yep.
**ubi apis- ibi salus**
Re: Couple of vacuum questions [Re: kewlynx] #973407 11/23/09 09:30 AM
F
frozen Offline OP
Great, thanks for the info. There are 2 vac lines that go to the A/C idle up system. One goes to a dashpot located near the throttle linkages. That line is connected.
The other line is the one that I can use some help with. Does anyone know where that line goes to?
Thanks again
-Pete
Re: Couple of vacuum questions [Re: frozen] #973408 11/23/09 09:57 AM
kewlynx Offline
It's been awhile, but seems to me it hooks up to the HAC valve if you have one. See the diagram, left side. Might also go to the charcoal cans. My '86 has the HAC and AC.
Re: Couple of vacuum questions [Re: kewlynx] #973409 11/23/09 04:00 PM
stock87 Offline
The dashpot only came on trucks with an auto transà the A/C valve (with the black cylinder thing on it) should have 2 linesà one to manifold vacuum, and one to the idle up diaphragm.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6222 MB (Peak: 0.7207 MB) Data Comp: Off Server Time: 2026-10-26 03:50:19 UTC
