Starter solenoid on 2004 TJ Sport #973427 11/23/09 12:54 AM
bradford_johnson Offline OP
Hello all;
I don't post often but always seem to find what I'm looking for on these pages. Yesterday intermidently, my starter failed to engage. After two or three turns of the ignition, the engine roars to life with no hesitation. I've checked the bettery terminals and the wireing and it all looks clean and am beginning to feel the solenoid has failed, but the intermitent nature of the failure gives me pause. I'm not that mechanical, but what else can I check before having the solenoid replaced?
2004 TJ Wrangler Sport
Re: Starter solenoid on 2004 TJ Sport [Re: bradford_johnson] #973428 11/23/09 01:46 AM
BigJim Offline
You have postd a typical failure of a solenoid! Usually they will pass current after a few tries.. that is typical of burnt contacts inside the solenoid.
Big JIm
Re: Starter solenoid on 2004 TJ Sport [Re: BigJim] #973429 11/23/09 08:00 AM
BobRowe Offline
I concur. Get a new solenoid.
And, as long as you're under the hood, clean up the battery terminals and the terminal ends on the battery cables.
Re: Starter solenoid on 2004 TJ Sport [Re: BobRowe] #973430 11/23/09 10:47 PM
Dealer reviewed and found the ignition switch to be defective. Having it replaced now.
Re: Starter solenoid on 2004 TJ Sport [Re: bradford_johnson] #973431 11/24/09 12:21 AM
BigJim Offline
Yep! That too.. If the solenoid doesn't click than one starts looking at the ignition key.
Big JIm
Re: Starter solenoid on 2004 TJ Sport [Re: BigJim] #973432 12/02/09 04:27 AM
update...There is an "actuater" attached to the ignition switch tat was broken. Seems the only way to get replacement parts is to buy an entire new steering column ($500+). Any ideas besides the local "pull yard"?
Re: Starter solenoid on 2004 TJ Sport [Re: bradford_johnson] #973433 12/02/09 06:17 AM
BigJim Offline
Nope! No other ideas here.
Big JIm
Re: Starter solenoid on 2004 TJ Sport [Re: bradford_johnson] #973434 12/02/09 06:24 AM
sunder Offline
If you are trying to avoid the cost, and don't mind it being a little rigged. Hot wire the starter solenoid with a generic starter button available at most autoparts stores. If you install it clean and semi hidden, it could even be an anti theft device. <img src="/forums/images/graemlins/kewl.gif" alt="" />
91 YJ
2 Seater Sand Rail
Handfull of other fun toys...
And a brand new, spit shined, B.S.
Oh, and a job to boot.
Re: Starter solenoid on 2004 TJ Sport [Re: sunder] #973435 12/02/09 04:33 PM
BigJim Offline
Yeah! What Sunder said times 10!
I'd eat a family of Dung Beetles before I'd spend five hundred bucks just to make the starter work.
Re: Starter solenoid on 2004 TJ Sport [Re: BigJim] #973436 12/02/09 05:19 PM
BobRowe Offline
I'd also vote for installing a separate starter button. Well over 10 years ago, the ignition switch on my CJ7 failed so that it would work in the ACC and OfF and RUN positions, but it wouldn't work in the START position. So I purchased a starter button switch for a couple of bucks, wired one side of it to a fused, constant-hot 12-volt source, and the other side of it to the starter solenoid.
Works fine. When I start the Jeep, I just turn the ignition switch to RUN and then momentarily press the new starter button to engage the starter.
This even has an advantage. If I leave the ignition switch in the OFF position and then press the starter button, I can use the starter to "bump" the engine around without worrying about it starting.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6355 MB (Peak: 0.7580 MB) Data Comp: Off Server Time: 2026-06-07 08:26:16 UTC
