Can I change Oil & dust pinion seal on rear diff third member W/O major problems? #973580 11/24/09 02:27 AM
banshee4785 Offline OP
I read the "How to change a pinion seal" from a search but I still have some questions.
It has gone bad before and we took it somewhere to have it changed.
I have normal air tools to do this if itÆs not a big deal.
To order the parts from Toyota it will be $30 and some change.
1.) oil seal
2.) dust seal
3.) washer plate
4.) spare nut
MY main question isà
How hard is it to change this pinion seal? Can I just loosen the pinion nut, slide off the flange, slide on the new seals and re-assemble?
I have the unit on a bench so that will help, but I am concerned about the correct pre-load being restored.
I dont know how you can count the number of turns of the nut when removed because the impact gun will zip it off.
D0 I need to order a few crush sleeves that go on the pinion, OR can I simply leave the one on there?
Should this be done with a breaker bar & socket or impact gun?
Any info would be GREATLY appreciated.
I have not done any gear swaps before.
95 4x4 ext cAB t100-
Re: Can I change Oil & dust pinion seal on rear diff third member W/O major problems? [Re: banshee4785] #973581 11/24/09 03:08 AM
kewlynx Offline
Zuk's website should clear up a couple things for you:
www.gearinstalls.com
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.5898 MB (Peak: 0.6385 MB) Data Comp: Off Server Time: 2026-05-29 19:53:29 UTC
