90 Trooper 4L30E ?
#974004
11/26/09 10:48 PM
It has been a long time guys. <img src="/forums/images/graemlins/patriot.gif" alt="" />
The old dog needs a front end rebuild. These parts are not a problem to locate.
However, I searched and ran across the HOW LONG WILL WE BE ABLE TO MAINTAIN OUR RIGS thread and I have a part that is not found through the local parts people.
Vehicle speed sensor for the 4L30E. I searched and found where Jerry mentioned this tranny having 2 of them. <img src="/forums/images/graemlins/scared.gif" alt="" />
I was wondering if any of you would have input on the below problem and where to locate the part.
The issue: When the truck is cold (less than operating temp) the tranny will inconsistantly go into limp mode on the 1 to 2 shift. Sometimes on the up shift and mostly on the down shift.
I am regularly getting the code for VSS and thought this was the issue. I do NOT always get the code when this happens. <img src="/forums/images/graemlins/confused.gif" alt="" />
I love the old Troop and will continue to try to repair as needed...until we run out of parts. <img src="/forums/images/graemlins/lol.gif" alt="" />
Thanks in advance,
1jackleg
I ain't real bright...
1990 Trooper LS, V6, Auto, 4door 132,000 miles 11/26/09
Re: 90 Trooper 4L30E ?
[Re: 1jackleg]
#974005
11/27/09 06:27 AM
Here's some good tranny info from the Transtec site, I expect if you do a search you might find more: http://www.transtec.com/rebuilder_news/2nd_q95r-n.pdfBTW the mode switch on the side of the tranny has been known to cause a lot of strange problems so you might consider looking at that. HTH.........ed
'90 Troop 3.4 LS '89 Troop RS (Has Valve Issues, needs Counseling) HI, I'm Ed and I'm a Trooper-holic! Keep On Troopin'......
[Re: 1jackleg]
#974006
11/27/09 05:21 PM
"THE V6 ,S ONLY HAVE ONE ACTUALL SPEED SENSOR ,IT IS THE SAME AS NO 1 SENSOR AND IT IS IN THE SPEEDO HEAD , AND HAS AN OUPUT SIGNAL OF 4 PULSES PER CABLE REVOLUTION, THIS SIGNAL IS USED BY THE CRUISE CONTROL AND THE ECM BUT IT HAS TO GO THRU THE SPD SENDSOR NO 2 WHICH IS THE UNIT MOUNTED UNDER THE LEFT DASH AND IT PROCESS THE SIGNAL SO THE ECM CAN MANAGE IT THE INPUT SIGNAL IS A BRN WIRE NOT THE YELLOW , THE YEL ON THE NO 2 SEN IS THE POWER LEAD , AND THE OUTPUT IS THE WHT WIRE WHICH IS THE BUFFERED SIGNAL , ALL IT DOES IS SMOOTH OUT THE SIGNAL PULSES ,, ALSO THE BRN WIRE ON NO 2 IS THE SAME AS THE OUTPUT FOR THE SPEEDO SW NO 1 IT WILL BE EASIER TO HOOK RIGHT UP TO THE NO 2 SENSOR , THE SENSOR NO1 IS NOTHING BUT A REED SWITCH THAT IS TRIPPED BY A MAGNET BEING ROTATED BY THE DRIVE ASSY IN THE SPEEDO HEAD , BRN WIRE INPUT SIGNAL WHT WIRE OUTPUT SIGNAL AT THE SENSOR OR BUFFER AS IT MAY BE CALLED , YOU CAN TELL IF SENSOR 1 IS WORKING BY TAKING AN OHMETER AND HOOKING IT ACROSS THE BRN WIRE AND GROUND AND SPINNING ON OF THE REAR TIRES JUST ENOUGH TO MAKE THE DRIVESHAFT TURN , IT WILL GO, ON OFF ON OFF , AS THE DRIVE SHAFT IS TURNED , , NOW TAKE A VOLTMETE AND GO TO THE WHT WIRE ON THE NO2 SEN AND SET IT TO ABOUT 5-6 VOLT DC TURN THE KET ON AND SPIN THE TIRE AGAIN AND THE VOLTAGE SHOULD FLUCTUATE A LITTLE BIT FROM WHATEVER IT IS READING... JERRY"
I went back 7 years and found this pearl from Jerry.
3 90 Trooper V-6's, 5 speed, 4.3L TBI, 31" BFG AT's, Fender Flairs, Bored intake, 1.6 roller rockers, MSD Coil, Jacobs Omni ignition. Heavy duty torsion bars, Rancho 9000 Shocks CAN'T SPELL, TO OLD TO LEARN, GOD BLESS YOU IF YOU CAN.
[Re: Ed Mc]
#974007
11/29/09 02:14 AM
Thanks had it fixed today by replacing the two top connectors and the shift shaft seal seals, looks like it isn't leaking anymore.
I can't seem to find the two bushings that are midpoint under the chassis. They look like a large bushing with a bolt through the middle connecting a couple of eyelets.
I want to replace all the bushings eventually but here in California not a lot of available sources that recognize descriptions. Downloaded a repair manual but it doesn't give parts numbers.
Getting about 15 mpg over all right now on Chevron Supreme 93 Trooper LS 255,000 as of 11/28/09
1993 Trooper LS Basically Stock 3/2 DOHC well over 255,000 on original engine and trans
