Rear wheel bearing 92 mits montero rs #974110 11/27/09 09:55 PM
hdmaster5312 Offline OP
Anyone here replaced a back wheel bearing. Seems to be a huge P.I.T.A.
Re: Rear wheel bearing 92 mits montero rs [Re: hdmaster5312] #974111 11/27/09 11:43 PM
haztoys Offline
It is a PITA ... Have you priced the bearing ... You may be shocked ... There really big and hard to hurt .. How did you kill one .. <img src="/forums/images/graemlins/cheers.gif" alt="" />... "I" would go used on this .. Clean it grease it .. Like I said there hard to hurt I bet you can find a good used one ...
Good luck
David
Hazardous Toys inc
Re: Rear wheel bearing 92 mits montero rs [Re: haztoys] #974112 11/28/09 12:15 AM
GreatWhiteShark Offline
It is a PITA ."I" would go used on this .. Clean it grease it .. Like I said there hard to hurt I bet you can find a good used one ...
Good luck
David
Hazardous Toys inc
i agree on this one. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Rear wheel bearing 92 mits montero rs [Re: GreatWhiteShark] #974113 11/28/09 12:46 AM
I have bought the new one 100. But it has to be replaced. Old one is causing major rumbling in car. Has anyone personally done ir have you had a shop do it?
Re: Rear wheel bearing 92 mits montero rs [Re: hdmaster5312] #974114 11/28/09 01:32 AM
haztoys Offline
Yes they will die at times and when they do can make a lot of rumble in the car ...If you have the right tools and know how you can I'm sure...I "am" a shop with the right tools and know how.... Changing a bearing on any of the Japanese axles is a job ... If you were near me I could do it ... Cant see how a home guy would want too..
Having your bearing die was a fluke ..
You mite want to at least look see what a shop would want to do it ..
Sorry on the break down
David
Hazardous Toys inc
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6068 MB (Peak: 0.6717 MB) Data Comp: Off Server Time: 2026-05-29 16:03:52 UTC
