Marvel Mystery Oil #974148 11/29/09 02:48 AM
Hermit Offline OP
Has anyone used Marvel Mystery Oil in their gas? I have used it in the past in other vehicles and noticed less knocking and chatter in the engine after running it for about 100 miles of so.
The mixture is 4oz to every 10 gallons of gas, so at 22.5 gallons for tank capacity of the avg. Trooper that works out to be about 9 oz per tank.
I would suggest that it be added about every 3rd-4th tank fill up as it work best from past experience at every 1500 to 2000 miles.
I haven't used it yet in my Trooper but am planning on adding it to my tank at next fill up and will report back if any changes, especially mpg changes after that.
93 Trooper LS 3.2, Auto, 255,000 @ 11/28/09
Have you used MArvel Mystery Oil in your Gas?
single choice
Votes accepted starting: 11/29/09 01:48 AM
You must vote before you can view the results of this poll.
Did you experience Postive Results?
single choice
1993 Trooper LS Basically Stock 3/2 DOHC well over 255,000 on original engine and trans
Re: Marvel Mystery Oil [Re: Hermit] #974149 11/29/09 06:12 PM
BigSwede Offline
My 3.2 doesn't clatter or knock, so I doubt I'll try it.
And most often the source of noise in the SOHC 3.2L (mine is a DOHC) is clogged hydraulic lifters. I would think an oil treatment is more likely to fix that than something in the gas. FWIW Isuzu recommends running 0W30 Mobil One to quiet the lifters by flushing out the varnish. Some have reported success with this, others have not.
Serenity now!
PHP: 7.4.33 Page Time: 0.014s Queries: 20 (0.011s) Memory: 0.6051 MB (Peak: 0.7016 MB) Data Comp: Off Server Time: 2026-11-03 04:53:31 UTC
