But the HO72 can be found in lots of yards
We've looked in the local junkyards with no luck. Most of them have newer stuff. The local junkyards tend to hold on to stuff for a little while, but if it doesn't sell, they get rid of it after awhile, I don't know why. (Insert: All the good rear ends are gone). Seems the rear end that he has, the last couple of years of production were around '72.
Pretty common part in this area. Check with the differential shops, LMC Chevy, etc., and look through magazines. Your truck likely has the Eaton, as you say, and shouldn't be difficult to source spider gears for, it's a Chevy afterall.
Only problem is, there are very few differential shops in the area and if they do diffs, they do other work also. the big diff shops are several hours east or more where most shops send their work to be done. Checked with Eaton and they do not support this diff anymore. I am sure someone makes replacement parts for it, especially the spider gears. We are trying to stay away from the dealer at this point. I have a buddy of mine I went to high school with that works the parts counter at the local Ford dealer. He says that if you want anything earlier than around the mid '80's you have to find an aftermarket or someone that has them. Ford might have them, but they are hard to look up (micro-fiche, not computer) and usually special order and a good lead time. I am assuming GM is the same. I have a friend that is the service manager at the local Chevy dealer, I may approach him about parts and see if he can find out if they are available.
I'll check out the links in John's post. Now that may take awhile to go through most of them on the 4x4 wire portal!!!!!
Thanks guys, I appreciate the help.
