A good reason to Change your Oil on a regular Basis! #974197 11/30/09 03:19 AM
GreatWhiteShark Offline OP
Re: A good reason to Change your Oil on a regular Basis! [Re: GreatWhiteShark] #974198 11/30/09 04:56 AM
Oyaji_Jon Offline
Umm, I'm pretty sure THAT's what is causing you transfer case gears to grind. Your lift likely has nothing to do with it... <img src="/forums/images/graemlins/lol.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: A good reason to Change your Oil on a regular Basis! [Re: Oyaji_Jon] #974199 11/30/09 05:09 AM
52degrees Offline
Let me guess... Poor performance and an SES lamp on due to the intake cam timing not advancing when commanded?
KG6VNX
Re: A good reason to Change your Oil on a regular Basis! [Re: Oyaji_Jon] #974200 11/30/09 05:10 AM
kewlynx Offline
Ya read my mind thar Jon.
**ubi apis- ibi salus**
Re: A good reason to Change your Oil on a regular Basis! [Re: Oyaji_Jon] #974201 11/30/09 05:35 AM
lolol that picture is of a bmw.
my shifter is hitting on the floorboard on bad bumps.
Re: A good reason to Change your Oil on a regular Basis! [Re: GreatWhiteShark] #974202 11/30/09 01:34 PM
sparkem Offline
There was a Chrysler 300C that came to our shop a couple months ago with an engine noise. It looked worse than that. Everything looked like it was covered in wax but it was oil sludge, no more oil in the oil pan.
Re: A good reason to Change your Oil on a regular Basis! [Re: sparkem] #974203 11/30/09 05:38 PM
52degrees Offline
Had an S-10 pickup come into a shop I worked at years ago. Pulled the plug and nothing came out. Stuck a screwdriver in and got a glob of sludge out. We used air pressure at the oil filler to get more sludge to ooze out. Gave it a good rinse with some fresh oil and sent them on their way (after having them sign an acknowledgment that we couldn't have caused their impending engine failure).
KG6VNX
Re: A good reason to Change your Oil on a regular Basis! [Re: 52degrees] #974204 11/30/09 07:12 PM
ScottFW Offline
In the mid-90s one of my coworkers had a neighbor lady ask him to come look at her Corolla because it didn't sound right. He asked her when she last changed the oil and she says "Oh I have to change that?" The car had 60,000+ miles and 4-5 years on the original oil before it started acting funny.
'85 4Runner (mostly stock) <img src="/forums/images/graemlins/kewl.gif" alt="" /> | '94 Miata <img src="/forums/images/graemlins/smile.gif" alt="" /> | '98 Saturn SC2 <img src="/forums/images/graemlins/rolleyes.gif" alt="" /> | '12 Ford Fusion (wife's company car)
Re: A good reason to Change your Oil on a regular Basis! [Re: ScottFW] #974205 11/30/09 07:20 PM
WTH causes that????
Re: A good reason to Change your Oil on a regular Basis! [Re: cmonty72] #974206 12/01/09 02:38 AM
ChristianCrawler Offline
the oil merge with the dirt in the engine it looks like to me <img src="/forums/images/graemlins/zombie.gif" alt="" />
PHP: 7.4.33 Page Time: 0.016s Queries: 16 (0.013s) Memory: 0.6387 MB (Peak: 0.7627 MB) Data Comp: Off Server Time: 2026-11-19 23:53:58 UTC
