Page 6 of 7 1 2 3 4 5 6 7
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974292 03/17/11 04:36 PM
zarktheshark Offline
very much appreciated. <img src="/forums/images/graemlins/cheers.gif" alt="" />
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974293 03/18/11 02:05 PM
Got your vmail. Sorry for lack of response. I can upload to MitsubishiLink.com for sure. Want to send me CDs? Or, send via YouSendIt.com?
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974294 03/19/11 12:28 AM
plh Offline
Big things are a coming, all 2k10 versions are now pre-installed in a nice and fancy VM.
This also means the Mac users on this forum can run ASA finally.
In order to use it, you'll need a copy of VirtualBox installed on your machine.
The VM clocks in at 2.1GB, and even with VirtualBox, ends up being smaller than if you installed all 4 versions individually. For once NTFS compression does some good...
Performance is very close to native, without much overhead.
I'll be uploading it as soon as I get something faster than cellular internet, so likely next Monday or so.
I should have a quick "how to install and use" guide typed up by then as well.
Very excellent, thanks for the effort. Now I'll have something besides NeXTSTeP to run on VirtualBox <img src="/forums/images/graemlins/lol.gif" alt="" />
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974295 03/21/11 03:06 PM
3
300D50 Offline OP
http://www.lickamom.com/ASA_VM/ASA_VM.zip
That's the .zip, You'll need to unzip and import the appliance in Virtualbox by going to file, import appliance, select the ovf file. After this, you can delete the unzipped copy.
I'll try to get some more detailed install instructions up for those that need them.
1989 Dodge Power Ram 50 w/ no engine <- rotten frame <img src="/forums/images/graemlins/frown.gif" alt="" />
1988 Power Ram 50 2.6 Long Bed
1990 Mitsubishi MightyMax V6, swapping to the Daimler-Benz OM617 3.0L I5 diesel
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974296 03/22/11 03:51 AM
plh Offline
Thanks, grabbed a copy & will try it out.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974297 03/28/11 11:30 PM
...This also means the Mac users on this forum can run ASA finally...
How about IOS (Ipad/Ipod Touch users)?
Regardless, great job!
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: off-roader] #974298 03/29/11 04:36 AM
3
300D50 Offline OP
If there's a way to run windows on it, I can get ASA installed.
Afaik, no easy way to on apple mobile devices. smirk
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: 300D50] #974299 03/29/11 06:43 AM
Ok thanks anyway. No virtual box app for iOS devices so too bad, so sad LOL. I guess I'll need to run it on a PC only then or buy a MacBook!
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: plh] #974300 03/31/11 03:57 PM
plh Offline
Got it running on my mac today (or should i say my MSI Windbook with MacOS) on a flight between Dalian and Shenzhen. Took a little messing around with the xml file, but once I figured that out for my Atom CPU everything loaded up and works great. Thanks for you efforts.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Mitsubishi ASA (CAPS replacement) available for download [Re: plh] #974301 03/31/11 08:12 PM
3
300D50 Offline OP
Should have just needed to import the appliance, I'll look into it.
What needed to be changed?
Glad it's working. smile
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6474 MB (Peak: 0.7683 MB) Data Comp: Off Server Time: 2026-07-09 15:34:34 UTC
