High idle #974888 12/03/09 07:11 PM
Bigcat Offline OP
I have a 92 toy 4x4 22re 5 speed and I rebuit it and all is fine except I have a high idle 11-1200rpm. I had throttle body checked at dealer and i adjusted the idle screw all the way in & no change, I adjusted it out & it started hunting probably around 1300 like it should. I did notice when I hit the brake it starts hunting. I think that means I have a vacuum leak. Any help would be appreciated.
Re: High idle [Re: Bigcat] #974889 12/03/09 09:50 PM
yota4runna Offline
Might be a problem with the Idle Air Valve.
Here's the test procedure from the FSM.
Re: High idle [Re: yota4runna] #974890 12/03/09 09:59 PM
Bigcat Offline OP
I'll try it thanks alot
Re: High idle [Re: Bigcat] #974891 12/10/09 03:24 AM
Bigcat Offline OP
Fixed it myself. I was tinkerin around with it and decided to take the throttle body off to check plate clearance and when I disconnected one of the water lines under the t/body I noticed something sticking out of the connection where the hose connected and found that it was clogged. Unclogged it and high idle went away and all is fine. Lesson learned!!!!
Re: High idle [Re: Bigcat] #974892 12/10/09 03:25 AM
kewlynx Offline
Very cool; thanks for posting back on it!!!
**ubi apis- ibi salus**
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6073 MB (Peak: 0.6716 MB) Data Comp: Off Server Time: 2026-06-07 06:57:28 UTC
