High idle
#974888
12/03/09 07:11 PM
I have a 92 toy 4x4 22re 5 speed and I rebuit it and all is fine except I have a high idle 11-1200rpm. I had throttle body checked at dealer and i adjusted the idle screw all the way in & no change, I adjusted it out & it started hunting probably around 1300 like it should. I did notice when I hit the brake it starts hunting. I think that means I have a vacuum leak. Any help would be appreciated.
Re: High idle
[Re: Bigcat]
#974889
12/03/09 09:50 PM
Might be a problem with the Idle Air Valve. Here's the test procedure from the FSM. ![[Linked Image]](http://i169.photobucket.com/albums/u225/toy4run/Toyota%204Runner/AirValve-1.jpg) ![[Linked Image]](http://i169.photobucket.com/albums/u225/toy4run/Toyota%204Runner/AirValve-2.jpg)
Re: High idle
[Re: Bigcat]
#974891
12/10/09 03:24 AM
Fixed it myself. I was tinkerin around with it and decided to take the throttle body off to check plate clearance and when I disconnected one of the water lines under the t/body I noticed something sticking out of the connection where the hose connected and found that it was clogged. Unclogged it and high idle went away and all is fine. Lesson learned!!!!
Re: High idle
[Re: Bigcat]
#974892
12/10/09 03:25 AM
Very cool; thanks for posting back on it!!!
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6017 MB (Peak: 0.6660 MB) Data Comp: Off Server Time: 2026-07-15 05:31:22 UTCValid HTML 5 and Valid CSS
