'88 Trooper Broken Hood Latch Cable
#975182
12/05/09 07:39 AM
Help, I broke the cable on my hood latch and can't open my hood. What now? <img src="/forums/images/graemlins/zombie.gif" alt="" />
1988 Isuzu Trooper II 150,000 miles starting to have more replaced parts than original parts 2.6 L 4 cyl 4X4 Never say die!
Re: '88 Trooper Broken Hood Latch Cable
[Re: dayoldpoi]
#975183
12/05/09 04:02 PM
You will need to toggle the hood latch manually. 12" long double jointed finger is a plus. I've never had to do it on an Isuzu product but have done it on other vehicles.
Where did it break? Inside latch or hood latch?
[Re: lttlbddy]
#975184
12/05/09 07:03 PM
The cable broke at the latch and I can't figure out how to get to the hood latch manually. Not much space by the grill or in the crack between hood and car body.
[Re: dayoldpoi]
#975185
12/06/09 01:25 AM
Last one I did was an S10 Blazer. I had to go in from the bottom and reach up. It would have been very helpful to have had another like vehicle with the hood open so I could see what I was trying to do.
Maybe someone can open the hood of an Old Troop and show how the latch actuates.
Good luck.
[Re: lttlbddy]
#975186
12/07/09 03:53 AM
I had to pull the wire using pliers and then was able to stretch the cable and wire tie it down to enable the cable to work until I can get another and route it through the little circuit it runs through in and out of the body and that will be a tedious process to say the least.
1993 Trooper LS Basically Stock 3/2 DOHC well over 255,000 on original engine and trans
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6018 MB (Peak: 0.6666 MB) Data Comp: Off Server Time: 2026-07-09 23:11:44 UTCValid HTML 5 and Valid CSS
