'88 Trooper Broken Hood Latch Cable #975182 12/05/09 07:39 AM
dayoldpoi Offline OP
Help, I broke the cable on my hood latch and can't open my hood. What now? <img src="/forums/images/graemlins/zombie.gif" alt="" />
1988 Isuzu Trooper II
150,000 miles
starting to have more replaced parts than original parts
2.6 L 4 cyl 4X4
Never say die!
Re: '88 Trooper Broken Hood Latch Cable [Re: dayoldpoi] #975183 12/05/09 04:02 PM
lttlbddy Offline
You will need to toggle the hood latch manually. 12" long double jointed finger is a plus. I've never had to do it on an Isuzu product but have done it on other vehicles.
Where did it break? Inside latch or hood latch?
Re: '88 Trooper Broken Hood Latch Cable [Re: lttlbddy] #975184 12/05/09 07:03 PM
The cable broke at the latch and I can't figure out how to get to the hood latch manually. Not much space by the grill or in the crack between hood and car body.
150,000 miles
2.6 L 4 cyl 4X4
Never say die!
Re: '88 Trooper Broken Hood Latch Cable [Re: dayoldpoi] #975185 12/06/09 01:25 AM
lttlbddy Offline
Last one I did was an S10 Blazer. I had to go in from the bottom and reach up. It would have been very helpful to have had another like vehicle with the hood open so I could see what I was trying to do.
Maybe someone can open the hood of an Old Troop and show how the latch actuates.
Good luck.
Re: '88 Trooper Broken Hood Latch Cable [Re: lttlbddy] #975186 12/07/09 03:53 AM
Hermit Offline
I had to pull the wire using pliers and then was able to stretch the cable and wire tie it down to enable the cable to work until I can get another and route it through the little circuit it runs through in and out of the body and that will be a tedious process to say the least.
1993 Trooper LS Basically Stock 3/2 DOHC well over 255,000 on original engine and trans
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6051 MB (Peak: 0.6699 MB) Data Comp: Off Server Time: 2026-11-03 04:53:05 UTC
