Electronic Trailer Brakes and Dual Battery
#975275
12/06/09 09:27 AM
Holden Frontera / Isuzu Rodeo '99 3.2L V6 auto
Hi All
Attempting to fit these items myself just a couple of questions
I need what is described in the instructions for the Electronic Brake Controller as the "cold or switched side" The block connector has 4 wires so what might be the switched side is a bit confusing. The wire colours are Orange, Green, Red and Grey with Red stripe. Which one should I connect to?
Dual Battery
I need to connect to the on position of the Ignition switch Is there an obvious easy access point near the battery or on the fire wall where I intend to mount the solenoid?
Thanks All in advance
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5818 MB (Peak: 0.6220 MB) Data Comp: Off Server Time: 2026-06-07 06:10:36 UTCValid HTML 5 and Valid CSS
