Can't find my truck title - anyone want to build a trail rig? #975449 12/07/09 06:53 PM
MarcDurant Offline OP
I bought a Raider a few months ago from a guy who was leaving the country. Figured I'd transfer the title when I got it on the road and passed the emissions test, etc. Well, somewhere in the past two months I managed to lose the title. Been looking everywhere for the past week - every box of truck parts in the storage unit, every drawer in every toolbox, under the seat of every vehicle I've been in. No go.
I've got about $2000 into the truck, it's a V6 manual transmission with 197k miles on it. The body is in awesome shape, every panel is clean except the driver's side front fender. Even the bumpers are straight. Engine & transmission feel strong, oil pressure is good.
Here's a list of the work I did:
  • GL-4 in transmission
    GL-5 in transfer case and front & rear diff
    rear brake shoes
    cleaned & greased front brake calipers
    flushed brake fluid
    flushed clutch fluid
    KYB Gas-a-just on all 4 corners
    3 new tie rod ends
    1 new lower ball joint
    Gen2 idler arm
    timing belt
    fuel filter
    cleaned VLAs, replaced one rocker arm
    water pump (although I have to redo the work, the gasket is leaking a little)
    wires, cap & rotor
    electric fan conversion
    swapped in a newer radiator
    new coolant hoses to firewall
    new thermostat
    air filter
    Replaced interior rugs with black, rubber-backed utility carpet
    boxed in the rear wheel wells
    two mini fire extinguishers
    catalytic converter
    greased the suspension
Still needs:
  • new windshield (current one is cracked, but usable)
    greased speedometer cable
    new check valve for headlight washers
    new latches for sliding windows (they've been ordered)
    stereo (still has the original head unit in 100% working condition)
If I don't find the title in the next week, I'll either be taking best offer or I'll pull the engine and put it in my other truck. What an idiot!
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
Re: Can't find my truck title - anyone want to build a trail rig? [Re: MarcDurant] #975450 12/07/09 07:27 PM
There must be a procedure for dealing with missing titles out there.
Most of there states out east no longer use titles after 15 years. Varies per state.
Do you have a Bill of sale?
Re: Can't find my truck title - anyone want to build a trail rig? [Re: OldColt] #975451 12/07/09 07:31 PM
1
1986powerram50 Offline
Ya, my 91 V6 MM I didnt get a title with 5months later I finally got one with some paperwork. its doable just a hassle <img src="/forums/images/graemlins/cheers.gif" alt="" />
--keRby
Ad Inexplorta
Re: Can't find my truck title - anyone want to build a trail rig? [Re: 1986powerram50] #975452 12/07/09 07:39 PM
Now that I think of it, when I bought my first SR from a dealer in New York I ended up loosing the title.
Being that the title had been transfered to my name I found I could go online, enter the Vin# pay a $20 and NYDMV sends a new title to the address they have on file. I had the title in 3 days.
Re: Can't find my truck title - anyone want to build a trail rig? [Re: OldColt] #975453 12/07/09 07:46 PM
CwnAnwyn Offline
Its not to much of a pain filing for a lost title here in CO. Do you have any contact with the previous owner? If so file for lost title with the DMV. It will go to him. Have him sign it over to you.
If you cant get ahold of him any longer than its just a little harder but not impossible.
Z
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI
84 K5, 350/700R4,36" TSLs, spooled fr/rr
74 VW Bug- volksrod project
68 VW Fastback, 2L T4 powered
Re: Can't find my truck title - anyone want to build a trail rig? [Re: CwnAnwyn] #975454 12/07/09 11:47 PM
Va_Stumpy Offline
When I got mine there was no title w/ it either.It sat on my father-in-law's property for 6 yrs after a guy moved out of a rental unit & stiffed him for 6 months rent. I took the VIN to a bud that ran a garage & after a couple months he was able to get me 1 thru some kind of mechanic's lien. I payed him an extra "fee" & was on the road . Good luck w/ your search.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Can't find my truck title - anyone want to build a trail rig? [Re: Va_Stumpy] #975455 12/07/09 11:58 PM
CwnAnwyn Offline
The problem in CO with a mechanics lien or Tow lien is most vehicles require a surety bond to get a title. Last time I checked it was 3+ times an appraised value (blue book??). When I bought my fastback it was without a title. The bond for it was going to be 4 or 5k. I didnt spend anywhere near that on the entire car! <img src="/forums/images/graemlins/zombie.gif" alt="" /> But I could skip the whole bond process since it was old enough. I just had to show I tried to find the last registered owners. Had to do a Title/VIN search, send out registerd letters and then take all documentation into the DMV. It wasnt hard.
If you dont want to go that route I know a few who have done the Broadway Title or ITS Title thing. Pay a fee, send them a "bill of sale" and you get a out of state title and plates for a year in your name. Then you can register it locally. Again its more money though.
Z
87 Raider TSI
Re: Can't find my truck title - anyone want to build a trail rig? [Re: CwnAnwyn] #975456 12/08/09 05:20 AM
Interesting suggestions, maybe I won't give up on it just yet. Before I lost the title I used it to get a temp plate in my name, so I should be in the computer system. The DMV refused to actually transfer the title at that time because I hadn't had the vin verification or emissions test yet. I'll run by the DMV tomorrow to see what they say.
89 Raider V6 manual
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6263 MB (Peak: 0.7273 MB) Data Comp: Off Server Time: 2026-05-29 20:00:35 UTC
