Anyone using universal cold air intake systems? #975471 12/07/09 10:26 PM
zarktheshark Offline OP
was looking at the UBI and then I saw this one from KnN. Since the filter is in a closed housing, this might be a good setup for 2.6L snorkel users, no?
http://www.knfilters.com/news/news.aspx?ID=1238
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: Anyone using universal cold air intake systems? [Re: zarktheshark] #975472 12/07/09 10:49 PM
89montero Offline
Maybe for a snorkel it'd be a good idea but other than that seems like a waste. Aren't the stock setups already pretty much a CAI? It takes the air from the fender instead of the engine bay. It doesn't have the fancy metal pipes and all but pretty much serves the same purpose. Do the 4clys use the same intake as the V6s(through the fender)?
I know I always laugh when I look under the hood of my dad's 06 wrangler and the intake is pretty much a hole in the top of the filter housing right there under the hood.
1989 Montero 4dr V6 3.0l
Re: Anyone using universal cold air intake systems? [Re: zarktheshark] #975473 12/07/09 10:58 PM
ES_97Sport Offline
Kinda cool. Sort of an expensive solution, IMO. It'd be pretty interesting getting that to bolt up in front of the MAF. Have to have something like Ingen's adapter since the K&N FIPK adapter is a huge oval.
Ingen
K&N
Re: Anyone using universal cold air intake systems? [Re: ES_97Sport] #975474 12/07/09 11:35 PM
Va_Stumpy Offline
Not sure that it's a great advantage over stock.The aftermarket unit is pulling a lot of hot air from the engine compartment;plus you're a lot more likely to get water in it.The stock set up takes in only air from outside.Well it's like that on the V6 anyway.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Anyone using universal cold air intake systems? [Re: Va_Stumpy] #975475 12/08/09 12:18 AM
CwnAnwyn Offline
4 Cyl pulls air from the fender, right behind the turn signal.
Looks nice but I would stick with a stock aircan.
Z
Do you think the average stormtrooper knows how to install a toilet main? All they know is killing and white uniforms.
87 Raider TSI
84 K5, 350/700R4,36" TSLs, spooled fr/rr
74 VW Bug- volksrod project
68 VW Fastback, 2L T4 powered
Re: Anyone using universal cold air intake systems? [Re: CwnAnwyn] #975476 12/08/09 02:29 AM
4cyl is way different than the 6cyl. i was going to try and put the v6 aircan in there, but may not now. In the end, the kn unit should work much like the v6. Also have no map sensors of anykink to worry about. [Linked Image]
'15 Subaru XV
'03 BMW i325
Re: Anyone using universal cold air intake systems? [Re: zarktheshark] #975477 12/08/09 02:51 AM
MBrannon Offline
I've installed a ton of these on the 6g72 engines. They come with the adapter.
http://www.3sx.com/store/comersus_viewItem.asp?idProduct=1576
Until you hit 400HP they really don't work any better than a nice clean drop in unit. If you have a nasty old filter, I'd get a k&n drop in.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Anyone using universal cold air intake systems? [Re: zarktheshark] #975478 12/08/09 05:49 AM
I have a V6 can in my SWB, connected to the turbo. I have moved the charcoal canister and fluid bottles though.
Re: Anyone using universal cold air intake systems? [Re: MontyMcV] #975479 10/11/11 03:02 AM
kleinhush Offline
i tried the injen cold air intake. this is also a universal [color:"black"]Cold Air Intake[/color]. if you need the installation process for this part, here i find an easy step process.
first is to determine the exact specification of your car.
next is to find the available parts the price manufacturer the fits your car.
if your car is running, turn it off. Wait until your engine has cooled completely before doing anything. Unplug the car battery, starting with the negative terminal (black or unmarked) and ending with the positive terminal (red).
Remove the stock air intake. This consists of removing the air filter, the big plastic box the filter was in, and the tube running from that plastic box to an opening in the engine bay somewhere. Parts of these will be attached by hose clamps, round metal rings which are can be loosened by turning the small metal piece on the end.
Once the stock intake is off, don't discard it. If the new intake you purchased should be damaged or broken, you still want to be able to drive your car. Set the intake aside until you know the new one works properly.
attach the new intake, and secure with hose clamps.
check the intake for play.
Re: Anyone using universal cold air intake systems? [Re: MBrannon] #975480 10/11/11 03:39 AM
socal1200r Offline
I'd agree with this. The stock intake setup on the 2.6L, combined with a K&N drop-in filter, would be WAY better than any of those so-called "cold" air intakes.
1989 Monty SWB, 2.6L w/MT, 15" alloys, 265/75 Dunlop Radial rovers, rear air shocks, Weber 32/36, SQ oil cooler, (SOLD Oct 2012)
Southeast VA, USA
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6414 MB (Peak: 0.7674 MB) Data Comp: Off Server Time: 2026-05-29 22:33:58 UTC
