Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") #976367 12/13/09 09:14 PM
Big_Iron_Tech Offline OP
Need some help. My sons Monty will not go into "Overdrive".
We checked the fluid level and quality, the are good.
I also checked and adjusted the TV cable. This changed the shift points but did not cause it to go into OD.
This problem happened all of the sudden.
Any ideas?
76 CJ5 (Part of the family)
89 SWB Monty 3.0 V6 ("Snot Rocket")
2003 F150 4X4
Re: Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") [Re: Big_Iron_Tech] #976368 12/13/09 09:23 PM
FrankR Offline
There is a 1-wire temperature activated switch on the front of the thermostat housing that does not allow O/D operation until the engine is at operating temperature. Remove the connector and ground it. An easy way to do it is to stuff a piece of small wire up inside the connector, reinstall it and ground the other end of the piece of wire. If the O/D now works, replace the thermo switch.
If that doesn't work, the issue is probably with the O/D OFF relay, but odds are it's the thermo switch.
Frank
Re: Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") [Re: FrankR] #976369 12/13/09 09:46 PM
Oyaji_Jon Offline
I'm glad someone asked this question as my overdrive has been acting fishy since I put my rig back together. THANKS!
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") [Re: Oyaji_Jon] #976370 12/13/09 10:07 PM
Frank, Thanks for the info. I was hoping to here from you. We will try your suggestion as soon as the Colts finish kicking the broncos butt!
2003 F150 4X4
Re: Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") [Re: Big_Iron_Tech] #976371 12/13/09 11:06 PM
The sending unit was the problem. Until I can get a new temp switch, I just ran a wire from the connector for the switch to a ground. Works fine. Thanks.
2003 F150 4X4
Re: Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") [Re: Big_Iron_Tech] #976372 12/15/09 09:46 PM
Oyaji_Jon Offline
I should say thanks, too, Frank. I unplugged the connector, scraped some of the green $hit off the connector, plugged it back in, and it works fine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Overdrive not working / 1989 3.0 automatic SWB ("Snot Rocket") [Re: Oyaji_Jon] #976373 12/17/09 11:58 AM
LandRaider Offline
Just stopping by to comment on your thread.
A+ for thread title
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Thank you for being a good poster!
Re: Overdrive not working / 1989 3.0 automatic - Same for a 2.6L? [Re: FrankR] #976374 12/18/09 10:49 PM
88raider4morgan Offline
Does this remedy work for a 1988 Raider with a 4 Cyl 2.6 L engine?
If so, can you help me locate the correct sensor wire to ground?
Thanks
Re: Overdrive not working / 1989 3.0 automatic - Same for a 2.6L? [Re: 88raider4morgan] #976375 12/18/09 11:08 PM
FrankR Offline
I'm not at all familiar with the 2.6L engine, but others here should know.
Frank
Re: Overdrive not working / 1989 3.0 automatic - Same for a 2.6L? [Re: 88raider4morgan] #976376 12/18/09 11:22 PM
LRJ4x4 Offline
Thanks
It's near the thermostat, follow the top radiator hose where it connects. This is only a temp fix, you want your sensor to work or your fuel consumption and other things will go whacky. It's a cheap sensor maybe $25.
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.009s) Memory: 0.6411 MB (Peak: 0.7636 MB) Data Comp: Off Server Time: 2026-11-17 11:23:56 UTC
