To Birfield or Not #976575 12/15/09 08:57 PM
SALMONHEAD Offline OP
Getting for my gear change and front axle rebuild and was interested in the pro's/con's of a birfield eliminator kit vs hardened birfield's/axles when running a locker in front. It seems like the price will be about the same for either (app $400). Any help out there?
Thanks
84 4RUNNER,22R,HEDMAN,WEBER 32/36,Davis Unified Ignition,33" BFG
Re: To Birfield or Not [Re: SALMONHEAD] #976576 12/15/09 10:16 PM
carter Offline
If you are going to spend the money, I'd run upgraded birfields. Better turning radius, IIRC.
Mike Carter
85 & 86 4Runners
My Website
Re: To Birfield or Not [Re: carter] #976577 12/15/09 11:57 PM
Staceman Offline
With 33" tires, you are good with stock axle shafts and birfields. I always was. 2 years of wheeling on 35" tires, each of my birfields had a crack. Noticed doing maintenance. I've always had a lock-rite locker in the front. I have since upgraded, using stock axle shafts, (I always take spares), and Longfield 27 spline (stock spline) birfields. Mabe if I go 39" or taller tires, I will go 30 spline all the way, but I don't see that for a long time.
Re: To Birfield or Not [Re: Staceman] #976578 12/16/09 03:00 AM
PARANOID56 Offline
all the birfield eliminator kits are junk. just do it right and get some longfields and call it a day
PARANOIDS PAGES Of all the things I lost, I miss my mind the most.
1984 Toyota 4x4 SR5 X-Cab
1971 Toyota FJ40
2006 Subaru WRX wagon
Re: To Birfield or Not [Re: PARANOID56] #976579 12/17/09 08:10 PM
Thanks to all, longfields and new axles it is. I'd rather upgrade while it's all apart and save a trail breakdown. We wheel all winter long here (often alone) and the Cascades can get really lonely (last Monday we saw zero vehicles all day). The run included miles of low/low running at 3500-4000 rpm with chains on both ends. The turn arounds when the trail is blocked (lots of falling trees in the winter)can be pretty hairy.
Re: To Birfield or Not [Re: SALMONHEAD] #976580 12/19/09 04:53 AM
missouriman Offline
long fields all the way.
two other toyota's with the elimiators went down on the run with broken axles.
they were trying to follow my wife, she has longs.
Re: To Birfield or Not [Re: missouriman] #976581 12/20/09 04:26 AM
OOP'S Offline
This is what they look like when they let go. This kit was a much higher quality then the one that is offered by Randys. It took almost five years to blow it but when it went it took out more then the kit. The shock load took out the PS u-joint along with the hub and R&P.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: To Birfield or Not [Re: OOP'S] #976582 12/20/09 03:19 PM
missouriman Offline
NICE.
my wife said theirs went bang bang..
one side then the other, one right after the other.
then of course with the elimiatiors... no spares.
backing up in a ravine where you were all most pulling a reverse wheelie.
Re: To Birfield or Not [Re: missouriman] #976583 01/01/10 07:53 AM
OOP'S Offline
NICE.
I drove out in one wheel drive because I also had a broken rear axle that I had broke earlier in the day.
David Fritzsche
Roseville, CA
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.6259 MB (Peak: 0.7292 MB) Data Comp: Off Server Time: 2026-07-09 16:45:02 UTC
