Oil pressure / valve stem seals questions #976621 12/16/09 01:52 AM
Hitndahedfred Offline OP
I noticed on my 89 Raider. That when I am idling a while or going slow that it smokes a bit when I get back on the throttle. From my old jeepin days this is telling me I have some seepage in the valve stem seals. Is this a correct assumption? I have the 3.0 V6 with a 5 speed. This vehicle is fn remarkable. Damn near better than any Jeep I have owned (cept the built up ones) My next question is ,,, just how hard is it to replace those valve stem seals?
1989 Raider, 3.0 V6, 5 spd.
Re: Oil pressure / valve stem seals questions [Re: Hitndahedfred] #976622 12/16/09 03:47 AM
Va_Stumpy Offline
I had the same problem w/mine. W/ the correct valve spring compressor it's not to difficult.The problem that I ran into was that 4 of the 6 exhaust valve guides had retreated into the head. I hope your repair turns out better than mine.
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Oil pressure / valve stem seals questions [Re: Hitndahedfred] #976623 12/16/09 03:55 AM
Oyaji_Jon Offline
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Oil pressure / valve stem seals questions [Re: Oyaji_Jon] #976624 12/16/09 04:12 AM
Va_Stumpy Offline
Great link...good advise.I didn't use the rope trick I rigged an air fitting into the spark plug hole.It may never happen;but I was afraid the rope would knot up & I'd have to pull the head.I had to pull the engine after all so I guess that was a mute point. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Oil pressure / valve stem seals questions [Re: Oyaji_Jon] #976625 12/16/09 11:45 AM
I did a search and could not find this. It;s nice to know I do NOT have to remove the heads to do this. Thanks all for your helpl
Pics are coming,,,,I promise but with the holidays and all,,,time is at a premium with work and all.
GREAT TECH WRITEUP
Fred
Re: Oil pressure / valve stem seals questions [Re: Hitndahedfred] #976626 12/16/09 04:58 PM
Oyaji_Jon Offline
I did mine with air as well. I purchased the spark plug hole adapters from Napa for ~$14.
Good luck.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Oil pressure / valve stem seals questions [Re: Oyaji_Jon] #976627 12/17/09 12:50 AM
8
89IsMine Offline
Be careful to clamp the cams down at the backside with the #4 bearing caps so that the timing belt stays properly tensioned and doesn't skip a tooth when you rotate the engine. I missed that step, and consequently ended up replacing my timing belt and water pump. Probably a blessing in disguise, but it's extra work...
Eric W.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6169 MB (Peak: 0.6957 MB) Data Comp: Off Server Time: 2026-06-07 08:40:21 UTC
