Re: '96 Sportage P0303 Mechanical or Electrical? [Re: Iron] #976865 12/21/09 02:30 AM
P
PatrickB Offline OP
I did ask the dealer. He didn't want to elaborate on their test procedure but assured me that diagnostics showed the valve to be faulty. I believe them to be right now that I've established that there is a good spark at #3 and that it has less than half the pressure of cylinder #2.
Thanks,
Patrick
Re: '96 Sportage P0303 Mechanical or Electrical? [Re: PatrickB] #976866 12/21/09 04:12 AM
Everet Offline
Patrick,
You should be able to get a valve job done for less than $300.
You will need to get a head gasket set too so when they do the work, they have new valve seals. If you haven't changed the water pump and timing belt, I would suggest that at this time too.
Check out this ebay auction for water pump and timing belt: ebay
What was the special tool you needed for removing the head?
Have the shop doing the head work remove the spark plug.
Good luck and keep us posted on the progress.
Re: '96 Sportage P0303 Mechanical or Electrical? [Re: PatrickB] #976867 12/21/09 04:18 AM
Everet Offline
Thanks,
Patrick
What's with these dealers...they think they hold the secrets to the Holy Grail? I would have told the guy to...never mind. <img src="/forums/images/graemlins/scared.gif" alt="" />
When it is running good, just take it back and tell him if he would have been more forthcoming with information, he would have gotten the job. NOT!!! Life is to short for that kind of BS.
Re: '96 Sportage P0303 Mechanical or Electrical? [Re: Everet] #976868 12/21/09 04:34 AM
Hydra747 Offline
Thanks,
Patrick
x2!
You Sing It Brother!
Re: '96 Sportage P0303 Mechanical or Electrical? [Re: PatrickB] #976869 12/21/09 11:36 PM
jaboo5322 Offline
Hi Dennis,
Great advice on the anti-seize for the plugs. My number four plug is seized. I was lazy last service and sent it to a dealer. I'm afraid of pulling the head-thread if I force #4 out, so I've left it for now.
Regards,
Patrick
I had the same problem my first plug change. What a scary experience. Got lucky. I had to also change the harness feeding the coils. Plastic on the connectors were brittle and fell apart. Was whole problem with missfire. Changed both coils also. <img src="/forums/images/graemlins/smile.gif" alt="" />
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6150 MB (Peak: 0.7142 MB) Data Comp: Off Server Time: 2026-05-28 01:02:45 UTC
