Air Bag Check Light Flashing #977506 12/22/09 09:44 PM
HarleyJohn Offline OP
I had the dash pulled on my '98 4-door Sportage to replace the instrument cluster. The knee air bag was disconnected, and then reconnected when the dash was replaced. The air back indicator light is now flashing. It won't reset/erase using the standard code reader that clears the CEL codes. Can anyone tell me how to reset the air bag codes? Thanks.
Re: Air Bag Check Light Flashing [Re: HarleyJohn] #977507 12/22/09 10:54 PM
Axe Man Offline
Kia Moderator Emeritus
It has to be reset with a Kia Pro Scan Tool. Only dealers have access to this tool so you must visit them to have it reset.
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Air Bag Check Light Flashing [Re: Axe Man] #977508 12/22/09 11:33 PM
Hydra747 Offline
I might further add in the area of safety:
You should remove the fuse in the mean time so as to negate the possibility of the airbag from going off while driving.
And replace that fuse prior to them resetting it with correct equipment and propper year of vehicle.
Should be around $85 to $100 <img src="/forums/images/graemlins/scared.gif" alt="" />
-----for just 1 minute of resett----
Re: Air Bag Check Light Flashing [Re: Hydra747] #977509 12/22/09 11:59 PM
Axe Man Offline
Hydra, that's not true. The airbags are not more prone to going off when the system detects an error.
Yes, unfortunately the dealer will rape you just to reset the system.
Re: Air Bag Check Light Flashing [Re: Axe Man] #977510 12/23/09 12:23 AM
Hydra747 Offline
Thanks AXE, (I would still remove the fuse though). <img src="/forums/images/graemlins/patriot.gif" alt="" />
I know right?
...Well it just so happens that I know a guy here in the Rio Grande Valley <no names to protect the innocent>...$30 for re-set
<img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Air Bag Check Light Flashing [Re: Hydra747] #977511 12/23/09 12:51 AM
6
69442 Offline
-----for just 1 minute of resett---- [/quote]
That's why their called a stealership <img src="/forums/images/graemlins/angry.gif" alt="" />
Call your local non-dealer Body Shop and they should be able to hook you up with a cheaper reset!
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Air Bag Check Light Flashing [Re: HarleyJohn] #977512 12/23/09 03:16 PM
Thanks guys,
I was worried it'd be something like that.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6204 MB (Peak: 0.7123 MB) Data Comp: Off Server Time: 2026-06-07 07:24:43 UTC
