check engine light #977536 12/23/09 03:30 AM
kjishikawa Offline OP
My CEL just went on. How do I pull the codes on a 3.0? This is on a 90 ram50. Thanks.
Re: check engine light [Re: kjishikawa] #977537 12/23/09 06:52 AM
Bernoulli Offline
If it came on when your mileage was a multiple of 50K, it can be reset by a switch on the back of the instrument cluster.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: check engine light [Re: Bernoulli] #977538 12/23/09 08:16 AM
If it's you're Maint Required light then yes, the switch in back of your instrument cluster will fix this problem.
If on the other hand it is actually a Check Engine light then there should be a code being stored in your ECU.
Here's how to read the code...
First you'll need to access the Diagnostic connector behind your glove box.
Next you'll need a non-digital multimeter to read the codes... Here are the procedures to do that.
Here are what the different codes mean...
Re: check engine light [Re: off-roader] #977539 12/23/09 11:08 AM
Thanks, I found it in my FSM.
Re: check engine light [Re: kjishikawa] #977540 09/16/11 08:25 PM
TerraXpeditions Offline
Does the above procedure work for a 1995 Gen II as well?
Re: check engine light [Re: TerraXpeditions] #977541 09/16/11 08:33 PM
I'm not sure but to doublecheck, download the FSM (Factory Service Manual) from mitsubishi links dot com and it should show the procedure and along with the correct connector & relevant pins to check along with a chart of the codes.
Oh and if it's not clear, you'll need an analog multimeter (not a digital one) to do the check.
HTH
Re: check engine light [Re: off-roader] #977542 09/16/11 08:37 PM
Mitsubishilinks.com wont download the files? even tried using google's document viewer...
Re: check engine light [Re: TerraXpeditions] #977543 09/16/11 08:40 PM
Sure it will. Simply right click, the save as...
<img src="/forums/images/graemlins/wink.gif" alt="" />
Re: check engine light [Re: off-roader] #977544 09/16/11 08:43 PM
Did that too... said the .pdf files are damaged...?
I've got it downloading on my phone (that will be a pleasure to find the info i need... joy....)
Re: check engine light [Re: TerraXpeditions] #977545 09/16/11 09:02 PM
I've pulled them down at home before w/out issues. I don't believe he's messed with the files so that's likely a network issue. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6414 MB (Peak: 0.7664 MB) Data Comp: Off Server Time: 2026-05-29 15:01:04 UTC
