88 dodge raider 2.6 5speed #977922 12/27/09 12:39 AM
Angrybooger2 Offline OP
Hey guys, i have been reading up on raiders and monteros for a couple of weeks here but i dont know if it's just me or what.
I have been trying to find out what other cars i can pull a 2.6 out of that will bolt up to my tranny with out any mods.
I bought the Raider for $250 and was told it only needed a head gasket but i see that there is water and sand in two of the cylinders and the crank shaft wont turn.(i only weigh 130 but my dad who weighs in the high 200's cant turn it with the breaker bar either)i dont have the space or real knowledge to rebuild and buy all of the parts i need.
so i was hoping i could get some help.
you guys really know your stuff so i figured there is no one else better to turn too smile
thanks in advanced
-Justus
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
15X10 vintage enkei's
Re: 88 dodge raider 2.6 5speed [Re: Angrybooger2] #977923 12/27/09 12:56 AM
It's not hopeless but you have your work cut out for you. Raiders, Montero's and D-50 pickups are bolt ins. I guess if you needed to do it in a hurry you could grab a motor out of Dodge Conquest or Mitsubishi Starion and (blasphemy) <img src="/forums/images/graemlins/shame.gif" alt="" /> take all the turbo stuff off and drop it in with just a few mods. There are enougfh guys on here, quite a few out on the left coast who could probably help out, even going so far as to help you do it. If they would, I'd hope they'd talk you into the extra work of the two cars turbo system, but if not, maybe they could put the turbo stuff to work for the cost of doing the swap <img src="/forums/images/graemlins/smile.gif" alt="" />. MY 2 cents, and good luck!
Re: 88 dodge raider 2.6 5speed [Re: Mudraider] #977924 12/27/09 02:22 AM
thank you sir, i appericiate it.
i saw on wikipidea(which i know isnt all true)
that there are a number of cars with the same motor but im guessing because of the different bell housings and drive trains that only the monteros/raider and d-50's swap in with ease.
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: 88 dodge raider 2.6 5speed [Re: Mudraider] #977925 12/27/09 02:45 AM
Try here, via car-part.com searching all of Kali:
A-1 Auto Dismantlers, Inc.
2707 Pittsburgh-Antioch Hwy
Antioch, CA 94509
Phone: 1-925-777-1515
Fax: 1-925-777-1872
It's an 89 plymouth arrow truck motor, m/t w/ about 120k miles.
Re: 88 dodge raider 2.6 5speed [Re: fasteddy] #977926 12/27/09 03:12 AM
Antioch, CA 94509
Fax: 1-925-777-1872
oh wow thanks!
the motor has more miles then my truck has but this should do fine!
now i need to sell my rims and tires for the money XD
oh the joys of being an unemployed hs grad.
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: 88 dodge raider 2.6 5speed [Re: Angrybooger2] #977927 03/29/10 09:35 AM
well, i bought an engine today. it was a running engine from a d-50 <img src="/forums/images/graemlins/smile.gif" alt="" />
i should be getting some stuff to clean it up..
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: 88 dodge raider 2.6 5speed [Re: Angrybooger2] #977928 03/29/10 03:03 PM
<img src="/forums/images/graemlins/kewl.gif" alt="" /> Good luck with that. Keep us up to date on your progress. Any questions, we're always here.
Re: 88 dodge raider 2.6 5speed [Re: Mudraider] #977929 03/30/10 03:29 AM
thank you sir, will do.
well i need a new or good used radiator.
the fins on the back of my radiator are rusted pretty bad and are breaking off with the slightest touch.
but on the plus side i got some small parts today. carb gasket, oil, oil filter etc...
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: 88 dodge raider 2.6 5speed [Re: Angrybooger2] #977930 04/02/10 10:24 PM
what do you guys use to take out the bolts holding the engine and tranny together?
88 Dodge Raider
1.5" lift
32"X11.5" A/T tires
Re: 88 dodge raider 2.6 5speed [Re: Angrybooger2] #977931 04/02/10 10:49 PM
RigilKent Offline
I use a wrench but for the top two you can only get about 1/8th turn at a time while using the open end and turning it over every time. Its a pain but you cant fit anything else in there.
84' Montero 2.6L SWB
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6392 MB (Peak: 0.7640 MB) Data Comp: Off Server Time: 2026-05-29 22:24:27 UTC
