Brands for certain parts?? #978026 12/27/09 09:29 PM
toyotadriver Offline OP
I need to buy some parts for my Toyota T100 SR5 4x4 3.4L in a couple months when I get home. I have found that the local parts store's parts aren't always the best. I want to buy some high quality parts without paying the dealer's price. I buy most of my stuff on line usually.
Here's what I will be needing:
Water Pump
Timing belt
Contacts and brushes for the starter
Brushes for the alternator
Inner front pass side wheel bearing (race has spun in the hub so I think I'll probably end up needing a new hub too)
I think I'll probably end up buying the brushes and contacts at the dealer. The rest of the parts I need to find a place to buy them at. Any brand recommendations as well as brands to stay away from??
Thanks.
Re: Brands for certain parts?? [Re: toyotadriver] #978027 12/28/09 04:55 AM
kewlynx Offline
Stay away from NAPA's water pump. Been there, done that. You'd be amazed at how different the impellers are, aside from the fact I had a 22R pump from NAPA fall apart in less than a year.
I usually take my starters and alternators to a local automotive electrical rebuilder like the dealer does here. Brushes/holder for the alt. at the dealer is cheap enough.
See if you can get the new hub out of a junkyard; www.car-part.com If not, then take a look at www.rockauto.com's prices.
**ubi apis- ibi salus**
Re: Brands for certain parts?? [Re: kewlynx] #978028 12/29/09 12:06 AM
Ok thanks for the info.
So...here's some brands. Yeah or nay?
Beck/Arnley
Dayco
Gates
AC/Delco
Bosch
Aisin
Re: Brands for certain parts?? [Re: toyotadriver] #978029 12/29/09 02:21 AM
CJMT100 Offline
AC/Delco is usually very good
Aisin is good
Dayco is so so
Rest is junk...
Re: Brands for certain parts?? [Re: CJMT100] #978030 12/29/09 02:32 AM
kewlynx Offline
x 2 there.
Re: Brands for certain parts?? [Re: kewlynx] #978031 12/31/09 12:39 AM
ErikB Offline
Toyota Moderator
I would buy the water pump from the dealer. Its high quality and comes with a very nice stainless steel and rubber gasket.
Important things like that that I don't want to have to mess with again because its buried under the timing belt I usually spend the extra few bucks on OEM.
http://home.4x4wire.com/erik
Re: Brands for certain parts?? [Re: kewlynx] #978032 12/31/09 11:04 PM
adam Offline
And again.
I buy light bulbs from the aftermarket suppliers. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Service parts I get exclusively from the dealer save for the few things OEM I've had to get out of the boneyards.
~Adam
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6181 MB (Peak: 0.6922 MB) Data Comp: Off Server Time: 2026-07-15 06:51:39 UTC
