Removing rear shocks #978478 12/29/09 11:06 PM
I
igneous Offline OP
What's the best/easiest way to remove the rear shocks? I slid under to try and remove top nut but it only spun the entire piston.
Re: Removing rear shocks [Re: igneous] #978479 12/30/09 02:51 AM
Jim_Paget Offline
The shaft on most, if not all shocks has two flats. Hold the shaft using those flats with one hand and unscrew the nut with the other hand. I find it easiest to hold the shaft with visegrip-type pliers.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Removing rear shocks [Re: Jim_Paget] #978480 12/30/09 04:00 PM
BigSwede Offline
What vehicle? Apparently Jim knows...
Serenity now!
Re: Removing rear shocks [Re: igneous] #978481 12/30/09 05:24 PM
87Montero Offline
I was never successful at properly disassembling a shock that went through a couple winters, but that was a rust belt.
If it's rusted on there, don't even bother (unless you're reusing it) bust out a sawzall or hacksaw and saw the top of the shaft off w/the nut on it.
Jim's got the right trick though, and apparently psychic too.
Re: Removing rear shocks [Re: 87Montero] #978482 12/31/09 04:09 AM
Jim_Paget Offline
No, I'm not psychic, but I have used the same trick on innumerable vehicles over the last 45 years or so.
Jim Paget
www.rrr4x4.com
Re: Removing rear shocks [Re: Jim_Paget] #978483 12/31/09 09:46 AM
holger Offline
Yes, Jim is right.
I usually use another technique: I keep the upper part of the shock really tight with my left hand and I use the wrench on the nut with my right hand. But I live in sunny California and probably my shocks are never really stuck.
Oleg
Deceased Rodeo'02 4WD.
Re: Removing rear shocks [Re: holger] #978484 12/31/09 04:01 PM
BigSwede Offline
I guess it is apparent what kind of shock design he is talking about...FWIW on my Trooper the rear shock has two "ears" at the top, not the straight threaded thing (which, BTW, the fronts do have).
Serenity now!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6157 MB (Peak: 0.6899 MB) Data Comp: Off Server Time: 2026-06-23 14:16:20 UTC
