heater core and hoses... #978635 12/31/09 06:49 AM
Dave Scott Offline OP
alright, before i open the box, anyone know for sure if the heater core for a 95 is the same as a 2002?
and
anyone know where i can get a cheap upper heater hose? not too cheap, but less than going to the dealer...
Re: heater core and hoses... [Re: Dave Scott] #978636 12/31/09 07:39 AM
londart Offline
heater core is same for 95-02 and if its dohc dayco makes an upper hose that sells for about $8 jobber @ my work, if its sohc dont know about others but dayco doesnt show 1
Lonnie
Auto Parts Professional
95 sportage sold but not forgotten
Re: heater core and hoses... [Re: Dave Scott] #978637 12/31/09 02:31 PM
bombardj1 Offline
as far a I can tell 95-00 are same, 01-02 are different part numbers and different prices from the dealer, I have a parts book for a 01, and when I type in the core # it shows 2001-2002, if 95 would fit it would show it, but thats only what I find, it still could fit others might know more.
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: heater core and hoses... [Re: bombardj1] #978638 01/07/10 01:01 AM
ok, reason i ask is that my 02 has a slanted hump, the 95 has a verticle hump in the front of the heater box...
so, anyone know a size difference before i start cutting?
or, anyone wanna trade?
Re: heater core and hoses... [Re: Dave Scott] #978639 01/07/10 06:01 AM
londart Offline
at my work we sell 2 different aftermarket brands, four seasons and proliance, and they both say 95-02 are the same....they may be different from factory but the differences are sometimes so minimal that the aftermarket does not change them to keep cost and inventory to a minimum,i know for a fact this is the case with many gm cores and the box has instructions and a piece of foam tape to make up the little bit of difference in size of the core...seems kinda cheesy but from what i understand is pretty common practice in the aftermarket field
Lonnie
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.005s) Memory: 0.6077 MB (Peak: 0.6719 MB) Data Comp: Off Server Time: 2026-06-07 05:44:27 UTC
