4 wheel drive crappy ! any ideas , ? #979404 01/04/10 07:10 PM
catman25 Offline OP
im a poor kia owner ! and not very handy with fixing stuff but i do try ! this yr i notice my 4 wheel drive hums alot ! it humms more when slowing down . Giving it gas isnt as noticable . Is there a seperate fluid to check or is it integrated with transmission fluid ? 4 wheel drive is still there but it really sound like it gonna fall off , Im not using oversized tired either , any suggestions based on this ?
check out my truck and please sign my guest book *CHECK OUT MY RIDE*
Re: 4 wheel drive crappy ! any ideas , ? [Re: catman25] #979405 01/04/10 07:43 PM
coup Offline
should have trans and transfer case fluids......
are you sure your hubs are working? if there is anything touching my 4wheel shifter it makes a hum noise....
jack all four wheels up and see if you can find hum or slack in drivetrain,,you can also trouble shoot hubs and see if they are working right.
a few times when rear driveshaft ujoints are bad i get a vibration and hum noise.
Re: 4 wheel drive crappy ! any ideas , ? [Re: coup] #979406 01/04/10 09:36 PM
catman25 Offline OP
ok time to show my ignorance . Where do you see transfer case levels ? Is that the plug /in the xfer case? Another issue i have which may be whole issue it self my alignment is way off ! which could be do to a warn part and putting pressure somewhere it shouldnt be . Cant wait for tax time
<img src="/forums/images/graemlins/frown.gif" alt="" />
Re: 4 wheel drive crappy ! any ideas , ? [Re: catman25] #979407 01/06/10 10:02 AM
2002_Sporty Offline
Maybe for future refference???
I took my vehicle down to one of those quick Lube places, not sure wich one. I had the oil changed there once before a trip. Now my vehicle is in their system. So every time after I go 4x4ing; I just stop by quick lube on the way home to have them check my fluid levels. All of them for free. Radiator, Diffs, trans, oil and washer fluid. They even top them off without charging me. So I continue to go there to get that service, and have even returned for oil changes.
2002 4dr Kia Sportage 4X4
Tires:235/75/15, Wheels: Black 15x8 Steel ProComp 2.5" B.S., Hubs:Warn Manual, Lift:3" UPYOURKIA, Trailer Hitch, Cargo Rack, Clinometer.
Re: 4 wheel drive crappy ! any ideas , ? [Re: 2002_Sporty] #979408 01/06/10 11:25 AM
jays2001 Offline
mine did the same and it was my needle bearings
01 w/31 in. mtr,winch,elec.fan ,4 in.suspension lift and 4in. body lift,front and rear hitch. NOT ENOUGH POWER so V8 and solid axles coming soon.2013
Re: 4 wheel drive crappy ! any ideas , ? [Re: catman25] #979409 01/20/10 02:10 AM
Hydra747 Offline
Slight vibration is all to normal indeed, with the KIA Sport!
What other probs are you getting?????
Describe "Crappy"?
..Please
Mikey
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6089 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-11-02 08:27:27 UTC
