Wheel Bore update and question about 15x12 wheels #979617 01/06/10 12:21 AM
sidecardog Offline OP
Here's update on my attempt to bore out the Chevy rally wheels that I picked up. Unfortunately, I didn't pay attention to the fact that the rally wheels were hub- centric, rather than lug-centric, so in the end I decided not to attempt to modify them since they wouldn't have any way to center themselves on the hub unless I could get the center incredibly precise.
So now I'm back to looking for another set of wheels. Here's the question: I can pick up a set of 15x12 wheels for super cheap but are they too wide to run 12.5" wide tires? My understanding is that 12" is too wide to hold the bead. I don't do too much airing down but I'd hate to lose a bead on one of my trips to the beach.
Also, I have the choice of putting my 31x12.5s on it or my 33x12.5s. I'll probably go with the 31s since I'll have less sidewall to bend and affect the bead.
Any thoughts on 12" wide wheels running 12.5s?
Thanks
Matt
2002 Montego Limited, 3.5 V6, 90K, just purchased
1990 Montero LS, LWB, AUTO, 3.0 V6, 250K, 2" SL, 31" tires--SOLD
1959 Vespa VBA150 all original w/sidecar
Re: Wheel Bore update and question about 15x12 wheels [Re: sidecardog] #979618 01/06/10 01:02 AM
0778drz110 Offline
i had a set of 35x12.5 on 15x12. I wouldn't run it IMO it looked retarded...i never got to air them down my POS Ford blew a tranny reversing out of the tire shop <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
i think you would pop a bead fairly easy especially airing down for sand
what wheels do you have now? 15x7 minimum for 12.5, to stay safe i'd say 15x10 max
Re: Wheel Bore update and question about 15x12 wheels [Re: sidecardog] #979619 01/06/10 01:17 AM
Va_Stumpy Offline
So you are talking about running 12.5" tires on a 12" rim?That's 1/4 th inch overhang on each side.... I really don't think you're gonna blow the bead off unless you are running 5 psi or less.Ask your guy @ the tire shop & see what he thinks. We don't have sand to run in where I'm located so maybe this is a biased opinion. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Va_Stumpy
89 Raider
"Never judge horsepower by exhaust"
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Wheel Bore update and question about 15x12 wheels [Re: 0778drz110] #979620 01/06/10 01:19 AM
Right now I have 15x7 wheels. I've been to every shop and junkyard in the area and it looks like my only option for getting 8" or 10" wheels is to buy them new. I was hoping to get some used ones since I plan on running 10.5" wide tires in the future and won't need the wheels after I burn through these current tires. 33x10.5s are in the future but for now, I got a great deal on 12.5s and I'm trying to make it work until I save up some more $$
Re: Wheel Bore update and question about 15x12 wheels [Re: sidecardog] #979621 01/06/10 01:32 AM
Va_Stumpy Offline
Post a "wanted to buy" on craigs list.The results may surprise you.My son has bought a ton of good stuff there.Well , it's a thought anyway.
Va_Stumpy
89 Raider
3.0
automatic
stock as a rock
Dual Bouncy Seats
Re: Wheel Bore update and question about 15x12 wheels [Re: sidecardog] #979622 01/06/10 01:33 AM
craigslist is your friend. That's where I found my 15x10's.
Re: Wheel Bore update and question about 15x12 wheels [Re: off-roader] #979623 01/06/10 01:38 AM
Yeah, craigslist is where I've been looking but no luck so far and it's been a few weeks.
Re: Wheel Bore update and question about 15x12 wheels [Re: sidecardog] #979624 01/06/10 01:46 AM
Took me almost if not over a year to find mine but I was looking for a specific rim design.
I used craigshelper.com and search a wider area. I was not opposed to driving as far as LA for a decent deal on the rims I wanted.
The search terms I used were '15x10' in the 'auto parts' section.
You can automatically rule out anything from a Jeep. Most chevy's although some had a 6x5.5" lug pattern. Also be careful that the center hole/bore is big enough to fit your hubs. I can tell visually by making sure the distance between the center hole and a lug nut hole is only so thick.
HTH.
Re: Wheel Bore update and question about 15x12 wheels [Re: sidecardog] #979625 01/06/10 01:55 AM
0778drz110 Offline
15x7 should work great
35x12.5 on 15x12
Re: Wheel Bore update and question about 15x12 wheels [Re: off-roader] #979626 01/06/10 02:07 AM
DRaider90 Offline
I would run 12.5s on an 15x7 rim before I would ever run them on a 15x12. You will be running a great risk of popping beads if you air down the tires any fairly decent amount. 8" wide rims are the best setup for 12.5s. 10" wide rims are decent, but then again you start running into bead popping issues when airing down. If you don't wheel the truck and just drive it on the road then you probably wouldn't have any issues.
The first time you rub your tire/rims up against a rut or a rock and the bead pops off, you will have wished you went with a narrower rim for the 12.5s.
88 Raider(Red):160k-Reman'd 2.6-5spd-Weber-SW Hubs-34x9.5 TSL-OffRd Pkg-1"Tbar-2"BL-CB
88 Raider(Silver):No 2.6/Bad KM145 Parts/Project
88 Montero(Brown):No 2.6,4.88s Parts/Project
[b]4X4 STICKERS,SHIRTS,ETC:
4WD Stickers AT COST.[b]
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6415 MB (Peak: 0.7684 MB) Data Comp: Off Server Time: 2026-06-22 07:34:48 UTC
