Fuel Tank Pump Lid #980421 01/10/10 05:31 AM
Temple Offline OP
I'm in need of the lid the holds the fuel pump, upon removing the tank i broke off the return line nipple on the cover. I'd dont know whats this part is called because i couldnt find it in any part stores online. Thanks for all your help <img src="/forums/images/graemlins/kewl.gif" alt="" />
"No obstacle brute force and ignorance cant overcome"
89 SWB RAIDER (IN PIECES)
06 F250 SuperDuty Axles
Currently saving for F-O-A 18" Coilovers
Cummins 6bta/5r110w/np271
Re: Fuel Tank Pump Lid [Re: Temple] #980422 01/10/10 06:08 AM
Can you resolder the nipple on? I can't help with this part, sold what I had already. Check with Jim (MI_Mitsu), TommyM, and anyone else in the Classys?
Re: Fuel Tank Pump Lid [Re: rxinhed] #980423 01/10/10 02:10 PM
mikes88troop Offline
please dont quote me here, but a couple years back, i ran into this problem on one of my troopers. the sending unit was available, but pricey and i just wanted a cheap way out. i ended up getting a repair kit for this at advanced auto ( think it was $12 ). all it was really was some straight brake line with a flared end as well as a " reduced end" i then pulled sending unit, pulled pump , was careful to blow out gas from unit. i ground nipples off flush , reamed out any burrs in holes. i then put a curve or bend as close as i could to original nipples and inserted the "reduced end " into holes. i used a jb weld type product as base of tubes cant recall exactly what ) to keep it in place. let it sit at least 24hrs to cure and only then hooked hoses back up. it worked fine, and i save closed to $200. might be worth checking into ? hope this helps - mike
Re: Fuel Tank Pump Lid [Re: mikes88troop] #980424 01/10/10 03:46 PM
mxmikie Offline
https://www.mitsubishiparts.com/oe_parts_catalog.html
Mechanical Catalog Fuel system , Fuel supply ,Fuel supply ,Fuel pump
1989 Mitsubishi Montero
Alternator
Automatic transmission
Body hardware
Brakes
Clutch
Cooling system
Electrical
Emission system
Engine
Exhaust system
Front drive axle
Front suspension
Fuel system
Cruise control
Fuel induction
Fuel supply
Fuel supply
Fuel pump
Fuel tank
Hvac
Maintenance & lubrication
Manual transmission
Rear suspension
Starter
Steering
Steering column
Transfer case
Universals & rear axle
Keyword or Part Number
Description Year MSRP Price Core Price Your Price
Fuel pump, montero, 2.6l 1989 $115.32 $83.03
index%2Ecfm%3Faction%3DgetLocator%26siteid%3D214364%26chapter%3DANP709%26appSectionid%3D6%26groupid%3D10025%26subgroupid%3D20067%26componentid%3D60663%26make%3D24%26model%3DMontero%26year%3D1989%26catalogid%3D1
Fuel pump, montero, 3.0l 89-90 $514.37 $370.34
Fuel pump, pick-up, 2.0l 87-89 $94.63 $68.14
Fuel pump, pick-up, 2.6l, from 4/87 1989 $115.32 $83.03
Fuel pump, van, wagon 87-90 $385.70 $277.70
Mitsubishi Home | Mitsubishi Accessories
Hyundai Home | Hyundai Accessories
Ford Home | Ford Accessories
Suzuki Home | Suzuki Accessories
* ALL parts & accessories sold on this website are 100% genuine (unless noted) and come with the FULL factory warranty good at any Authorized Dealer in the US.
* At this time we accept Visa, Master card, Discover, Money orders, and cashier's checks.
* We no longer accept American Express!
* S&H will be 10% of the your total purchase, with a $10.50 minimum.
* Items that are oversize and overweight will be charged actual shipping charges (ex. a hood will be approximately $100.00 and a door will be approximately $65.00).
* In order to keep our prices as low as possible, ALL new customers must designate their orders shipped to the "Billing Address" for the first 30 days. After 30 days, orders can be shipped to the "Ship To" address.
* Items too large for a national delivery companies ground service will be shipped freight collect.
* Due to the nature of this catalog, prices are subject to change at any time, even after placing your order!
* There are no returns on electrical items (installed or not).
* No refunds on freight charges (exclusions apply).
* Due to the nature of this electric online parts catalog, prices are subject to change at any time, even after placing your order! You will be notified of these changes before your order is shipped.
An Authorized Parts Dealer
MitsubishiParts.com, 1stSuzukiParts.com, 1stHyundaiParts.com and FordParts-Korum.com
are all a division of Korum Motors
111 River Road
Puyallup, WA 98371
Order information:
Call Toll Free (Not Technical Support)
Ford: 800-566-7058
Mitsubishi & Suzuki: 800-599-6775
Hyundai: 800-244-2705
MitsubishiParts.com
Copyright ® 2003 - 2009 MitsubishiParts.com
Powered by {1stautoparts.com}
Powered by Trademotion HACKER SAFE certified sites prevent over 99.9% of hacker crime.
Copyright 2009 Intelligentz Automotive Corporation
Our secure web pages are being hosted by (Intelligentz Automotive Corporation), who use a Network Solutions SSL certificate to ensure secure transmission of your information.
Re: Fuel Tank Pump Lid [Re: mxmikie] #980425 01/10/10 04:59 PM
i see the fuel pump for his, but not the pickup. is it the same as the 2.6 and 2.0 ? if so bob (87 montero) is looking for one
Re: Fuel Tank Pump Lid [Re: mikes88troop] #980426 01/10/10 07:27 PM
Temple Offline OP
I might have to go this route, maybe i can thread it in screw in some nipples but i'll have to take it apart to see what i can get away with, when i was trying to break the sending side loose that connection started flexing pretty good too, i think that whole thing is just old and fragile.
Re: Fuel Tank Pump Lid [Re: Temple] #980427 01/11/10 12:32 AM
mxmikie Offline
2.0 and 2.6 are the same Fuel pump, pick-up, 2.6l, from 4/87 1989 $115.32 $83.03
Re: Fuel Tank Pump Lid [Re: mxmikie] #980428 01/11/10 02:07 PM
i'm guessing he has a v6 from his sig ?
Re: Fuel Tank Pump Lid [Re: Temple] #980429 01/11/10 03:13 PM
Temple, I fixed this on my 92 back when I had it. There are other trheads since then where the same happened. Pretty easy to do along the lines of what's been discussed above. If it happened again, I would fix in a second if I couldn't quickly find a replacement for cheap.
I was just at the yard yesterday getting the MAF for Marius. The 91 I was in is clean for this area. Not sure on the drop-in unit though. It's at a Pull-A-Part. If it's good, it would be ~$25 with the pump. Not sure when I'll be back though. It's cold here and everything there is buried in snow. If you get jammed up with this, let me know and I'll see...
Re: Fuel Tank Pump Lid [Re: MontyMcV] #980430 01/11/10 10:45 PM
Temple Offline OP
Thanks, I dont think i'm in a big hurry, my raider is axleless right now going for the big 18"coilovers. with some 1/2ton axles
I'd really like to see if i could order some 90degree fuel fittings from summit racing and see if i could thread them in, i'd think they'd be alot stronger then stock..............
but again thank you everyone whos been giving my ideas and hope.
Dean
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6390 MB (Peak: 0.7551 MB) Data Comp: Off Server Time: 2026-10-24 02:35:28 UTC
