What Oil Pressure Is Normal? #980852 01/13/10 05:58 AM
89Montiero Offline OP
I noticed on my last trip in the Gen I Montero, my oil pressure guage stayed at the first line I believe it just says "2" at the first line then "4" then "6" as the oil pressure goes up.
Is that normal? I would have thought on a long trip or higher RPM's that it would change or at least come up to about the middle of the guage, does this mean I have low oil pressure? I have new valve guide seals and not burning a drop of oil.
another thought, I'm running 31 Mud tires. I was able to easily maintain 75-80 MPH but RPM's were pushing 4000. Maybe these Montero's are geared lower than I thought, what is the gear ratio on the Gen I's?
Just curious, thanks dudes.
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's
2005 Mitsubishi Montero Limited 3.8 V6
2011 Subaru Impreza Outback Sport
Re: What Oil Pressure Is Normal? [Re: 89Montiero] #980853 01/13/10 06:20 AM
KrzyDav Offline
Stock oil gauge are very inaccurate and very slow responding.
After years of disatifaction and worry I undertook a very overengineered and heavy duty aftermarket( Autometer)mechanical oil gauge installation. With suggestions from folks on here to improve responce and accuracy , I now have no doubt were the pressure is at all times on my 3.0 SOHC.
20/50w castrol
ice cold idle: 80 - 100 psi.
hot idle : 15 to 20 psi.
under load on flat highway at 3000 rph in 5th: 50-60 psi.
dave h.
Re: What Oil Pressure Is Normal? [Re: KrzyDav] #980854 01/13/10 04:28 PM
RaiderRuss Offline
Mine runs at near 6 at 50 mph. Best indicator is the dip stick.
1988 Raider ,2.6L, AT, Off-Road Packag
Re: What Oil Pressure Is Normal? [Re: KrzyDav] #980855 01/13/10 04:36 PM
StockRaider Offline
Original pump on my 3.0 Raider 175k
80PSI Cold Idle
30PSI Hot Idle
Brand new Melling oil pump on my rebuilt 3.0 Montero
90PSI Cold idle
35-40PSI hot idle
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: What Oil Pressure Is Normal? [Re: StockRaider] #980856 01/13/10 05:44 PM
zarktheshark Offline
I have the 2.6 with factory gauge. hot idle is around 3 and hwy speed is 4-6. For gears, stock is 4.62:1 for the gen1's.
'88 Raider. 2.6L dead...2.4L swap in progress, AT, 33's, 2 bouncy seat,AC, CC, 2.25 exh, 2" Tbar, 2" BL, rear DB, rear LSD,4.90's, SW hubs,gen2 uca's, KYB shocks, snorkel, elec fan, MSD.
'99 chev k3500 crewcab
'15 Subaru XV
'03 BMW i325
Re: What Oil Pressure Is Normal? [Re: zarktheshark] #980857 01/13/10 06:02 PM
Kevin C Offline
The 2.6 engines typicly have very high oil pressure compared to the V6. The 2.6 pump runs at twice engine speed and in a high capacity pump. 110+ PSI cold and 80 PSI hot at highway speeds is normal on the 2.6.
The V6 does not need as high a pressure to live.
Kevin
Re: What Oil Pressure Is Normal? [Re: Kevin C] #980858 01/13/10 10:18 PM
KrzyDav Offline
Yes the 3.0 does run low, appearantly by design. Specs on All Data, FSM , etc. allow normals like around 15psi. Seemed too low to me but that's what's written.
My pump is a Melling , too,,,at least the gears are. The gears have around 45k on them , the body must be at 75k.
dave h.
Re: What Oil Pressure Is Normal? [Re: KrzyDav] #980859 01/14/10 01:33 AM
torquemonster Offline
warm engine Idling oil pressure isn't too critical, as long as there is some pressure there you should be okay. my old 2.6 would hit 150psi on a cold start and when warm would idle around 50psi. Originally I only had a 0-100psi Automeater gauge and as soon as I installed it I wrapped it and wrecked it haha
Re: What Oil Pressure Is Normal? [Re: torquemonster] #980860 01/14/10 02:00 AM
Kevin C Offline
If you get 150 psi on a 2.6 most likely your pressure relief valve is bad or someone shimmed it. It's designed to open at 110-120 PSI.
Kevin
Re: What Oil Pressure Is Normal? [Re: Kevin C] #980861 01/14/10 05:43 PM
K_Raider Offline
Im curious if some people that are having the reading at 2 to 3 are reading the top numbers that are in orange? That is kg/cm, not the lbs/in which is the bottom numbers? I cant remember cold start lbs but my engine has alot of miles on it and I get 27lbs at hot idle and 45lbs at 55mph. And I need to change the oil... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors
89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels
99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6459 MB (Peak: 0.7659 MB) Data Comp: Off Server Time: 2026-06-21 19:04:23 UTC
