Re: No Heat BRRrrr [Re: 4ePikanini] #980954 03/02/10 03:34 PM
RECON45 Offline
I am having something similar. I had a small leak around the thermostat housing so I replaced the thermostat and gasket and upper radiator hose (it was swelled in areas) i had heater for over an hour or so when I first got it done. parked it it has been 2 weeks, I let it warm up and all I get is some lukewarm heat. It has been flushed out I have no clue whats going on now.
Re: No Heat BRRrrr [Re: RECON45] #980955 03/05/10 02:44 AM
Geophie Offline
Side note (gen 1 Blower Motor cleanup):
If your blower motor is going out or has totally stopped like mine did, you can pull it out of the vehicle and tear it down to clean it.
I had been dealing with a dying blower motor all this winter and it finally got some attention with some PB blaster fluid and compressed air (and a bit of the old brass wire brush). The blower motor looked as if satan himself took a dump in it.
Disassembles just like a little starter motor.
The hardest part was removal and reinstall...and maybe searching for one of the tiny brush springs on the garage floor.
-jeff
PS: I removed the negative battery terminal before I did this for fear of frying the ECU. It's under the blower housing and had to be pulled out first.
1991 4dr RS, ATK 3.0, auto. Now with zero trans fats!
Re: No Heat BRRrrr [Re: RECON45] #980956 03/29/10 09:00 PM
RECON45 Offline
I was reading the service manual and trying to better undestand the water valve and the damper lever on the heater core. How is the best way to check this? I have felt my hoses and the return hose is warm but not as hot as the supply line. I have luke warm air. So I know I am getting some flow which is good, but trying to see if it is my valve is not opening all the way open or a partial clog. any helps and pics of this check would be great. The diagrams are decent but actual pictures help out so much more. Thanks yall.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6007 MB (Peak: 0.6709 MB) Data Comp: Off Server Time: 2026-05-29 22:16:46 UTC
