Page 1 of 4 1 2 3 4
QUICK brakes question? #981153 01/15/10 10:20 PM
Hydra747 Offline OP
My break pedal almost goes to floor (not quite though). All the breaks are new plus the 2 rear cylinders and all were bled today at a small shop.
They suspect master cylinder......Which was replaced like 5 years ago.
The only symptom I got besides poor pressure is a loud spring type screeching noise when I step on the pedal.
Any Ideas?????
Thanks,
Mikey
Re: QUICK brakes question? [Re: Hydra747] #981154 01/16/10 01:17 AM
minydigger Offline
Are the calipers moving like they should? i had a similar issue with mine it ended up being a stuck caliper bolt.
94 Zj custom suspension and other stuff
01 F250 tow hoe 5" exhaust
00'sporty 3" lift 235's
Re: QUICK brakes question? [Re: minydigger] #981155 01/16/10 01:20 AM
Hydra747 Offline OP
Thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
Do it affect pressure too???
Any info is welcome!
BTW:kiaparts.net for new master cyl.=$150
Advance auto=$30! <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: QUICK brakes question? [Re: Hydra747] #981156 01/16/10 01:50 AM
bombardj1 Offline
air still in lines, rear springs inside drums not installed right. or adjusted right, does it pull to the right or left when the pedal it hit ? caliper sticking
2001 5sp. K&N stock filter 215/70/15
If your check engine light is on at least you know the light still works
Re: QUICK brakes question? [Re: Hydra747] #981157 01/16/10 02:06 AM
6
69442 Offline
[quote]Any info is welcome!
Check the lose nut behind the wheel <img src="/forums/images/graemlins/ignore.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: QUICK brakes question? [Re: bombardj1] #981158 01/16/10 02:37 AM
Hydra747 Offline OP
no air in lines (front and back)!
Calipers in front could be sticking....does it affect pressure or cause that noise????
Thanks
Re: QUICK brakes question? [Re: Hydra747] #981159 01/16/10 03:48 AM
bombardj1 Offline
get the rear off the ground did it in gear give it some gas and put brakes on do it a dz times and see if you hear the noise. then have a friend stand in the street and brake as you go by then have them stand on the other side and see it they can heard the difference and if front or back
Re: QUICK brakes question? [Re: bombardj1] #981160 01/16/10 03:53 AM
Hydra747 Offline OP
k.....done...and now what?
Re: QUICK brakes question? [Re: Hydra747] #981161 01/16/10 04:12 AM
bombardj1 Offline
if the fronts then the cal is sticking, ? brakes rear how about the drums ? is there a lip on the drums ? how about spring hard on rears ? if fronts 1 sticking because it does not return could have air even if bleed
Re: QUICK brakes question? [Re: bombardj1] #981162 01/16/10 05:16 AM
6
69442 Offline
Hydra, you check the lose nut behind the wheel yet <img src="/forums/images/graemlins/nana.gif" alt="" /> I know i'm no help, hard to diag from afar.
You really should have professionals look at that, don't want you goin off a cliff and wind'n up on Youtube <img src="/forums/images/graemlins/cheers.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6410 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-10-21 22:05:41 UTC
