22re timing jumper #981247 01/16/10 11:12 PM
MAC Offline OP
Just checked the timing on my 4Runner. Weird thing. The idle was a little high (not much.. need to clean the butterfly think) and when I jumpered the diag box there was no drop in idle speed/retard in timing. I brought the idle down (butterfly close by hand) and then the jumper worked. I have never noticed this before with any of the numerous 22res I have had. Could the TPS be not functioning properly. PS. I have been trying to figur out why the engine performance is feeling somewhat sluggish. Anyone experience this?
Re: 22re timing jumper [Re: MAC] #981248 01/16/10 11:41 PM
4Crawler Offline
Either throttle not closing fully or TPS mis-adjusted:
- http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml#Troubleshooting
Re: 22re timing jumper [Re: 4Crawler] #981249 01/17/10 04:58 PM
MAC Offline OP
Hi Roger, thanks for the reply.
My question is that IF my idle is a little high, will the tps (or something else) cause the non-response of the timing jumper?
Background scenario: The throttle plate has been hanging up ever so slightly when it gets very cold and it was hanging when I first tried the jumper...no jumper response... Nudged the throttle plate down by hand and viola! the jumper worked.
So...is the slightly 'high idle/jumper no work' normal function? ie. does any sensor or tps pick up the fact that the idle is high and disable the ability to retard w/the diag jumper?
Re: 22re timing jumper [Re: MAC] #981250 01/17/10 10:45 PM
4Crawler Offline
Yep, if the TPS IDL-E2 contact does not close, the ECU does not know the engine is at idle and the timing jumper does not work.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6054 MB (Peak: 0.6624 MB) Data Comp: Off Server Time: 2026-11-02 12:28:47 UTC
