Page 1 of 3 1 2 3
I am looking for a Gen 1 2.6L longblock #981510 01/19/10 04:55 AM
88raider4morgan Offline OP
Well the hits just keep on coming...
I was waiting to pick up my "new" Raider when just after installing the rebuilt transmission my mechanic informed me that the head was cracked. For those of you at home keeping score that's:
New brake system
Body work
Paint job
Rebuilt transmission
Now I need to decide if I want to fix the crack in the head and finish the top end job or start over and install a used or remanufactured engine.
Does anyone now where I can find a working 2.6 L engine?
I am just about at the end of my rope here...
Re: I am looking for a Gen 1 2.6L longblock [Re: 88raider4morgan] #981511 01/19/10 04:59 AM
MarcDurant Offline
Too bad he waited until after the transmission was done to figure out that the head was cracked. Sounds like something I would do (to myself).
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
Re: I am looking for a Gen 1 2.6L longblock [Re: 88raider4morgan] #981512 01/19/10 05:04 AM
Kevin C Offline
All used 2.6 heads are cracked, its just a question of is the crack leaking? Or was it a head gasket?
Kevin
Re: I am looking for a Gen 1 2.6L longblock [Re: Kevin C] #981513 01/19/10 05:32 AM
0778drz110 Offline
Clearwater head-about 350, plus install, but it won't break again
or
There are 2 2.6s in a yard in Bradenton, FL as of couple weeks ago
Re: I am looking for a Gen 1 2.6L longblock [Re: 0778drz110] #981514 01/19/10 07:51 AM
89Montiero Offline
That is discouraging. I've been in a similar situation with an Isuzu Trooper. I just wanted to take it to the junk yard after it kept breaking down (head gasket problems et al) The good news is, you have a great looking truck with a rebuilt transmission and brakes, what else could really go wrong other than regular maintenance? I'd probably go with the clearwater head and get that sucker running again, if you go with a used engine, not only are you going to have the labor to remove and replace, the replacement is gonna likely have issues too.
Now isn't the time to bring this up but that is why I held out and waited for the right V6 raider, less problems. (with the heads anyway)
Good Luck, it shant be long before you're ready to roll
1989 Mitsubishi Montero SWB V6. Torsion bar crank, Gen II springs, 31X10.5" BF Goodrich M/T's
2005 Mitsubishi Montero Limited 3.8 V6
2011 Subaru Impreza Outback Sport
Re: I am looking for a Gen 1 2.6L longblock [Re: 0778drz110] #981515 01/19/10 03:48 PM
Please provide contacts for both the Head and Engines.
Thanks
Re: I am looking for a Gen 1 2.6L longblock [Re: 88raider4morgan] #981516 01/19/10 06:45 PM
No one here will recommend a reman engine. Only advice there is to find a reputable local shop.
As for the head, like mentioned above, Clearwater Cylinder Heads (cylinder-head.com, I think). Yes, as is Clearwater FL. Get their new cast non jet-valve one.
Re: I am looking for a Gen 1 2.6L longblock [Re: 89Montiero] #981517 01/19/10 07:37 PM
Kevin C Offline
Now isn't the time to bring this up...
Your right, good thing you didnt. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Final verdict [Re: 88raider4morgan] #981518 01/20/10 12:59 AM
I think I'm going to bite the bullet and buy a remanufactured engine for $1480. The old one needs a new timing chain and guides, oil pump, water pump and the new head. Once I added it up there was less than $500 difference between a fixed engine with 200,000 mile and one with a 3 year unlimited miles warranty.
Sometime next week my Daughter will have a brand new 22 year old truck...
Re: Final verdict [Re: 88raider4morgan] #981519 01/20/10 01:23 AM
plh Offline
If you go the entire rebuilt engine route, make sure it comes with a new non-jet valve head. Probably many more things to look for also - something about crank bearing journal grinding technique if I remember correctly...
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7619 MB) Data Comp: Off Server Time: 2026-06-07 06:03:16 UTC
