Under Coating the Frame #981860 01/21/10 01:49 AM
Hydra747 Offline OP
I got some friends (ya, I actually do) <img src="/forums/images/graemlins/lol.gif" alt="" /> that own a mechanic shop here in town. The owner is working on a project car (81 Camaro) and did the underside, but he also changed all the bushings and joints too!
It looks really nice. He said that I could use their shop on the weekends for my Sporty project for free of charge......Sporty project that seems to never end. <img src="/forums/images/graemlins/kewl.gif" alt="" />
The buckets are like $24 each and I should need about 3 for many coats.
I remember that Jaboo and Bomber have lot's of rust underneath...and I don't want that to happen to mine.
You see, I go to the beach here in south Texas and I thought that it would be a good investment.
Has anyone elso thought of doing this and with what type??
Thanks,
Mikey
Re: Under Coating the Frame [Re: Hydra747] #981861 01/21/10 02:03 AM
6
69442 Offline
Don't waste your time nor money on undercoat for corosion purposes living in Texas.
Driving on the beach won't do jack to your rig unless you take it snorkeling <img src="/forums/images/graemlins/lol.gif" alt="" />
Now, if you want better sound deadner then go for it <img src="/forums/images/graemlins/kewl.gif" alt="" />
just my 29 cents <img src="/forums/images/graemlins/cheers.gif" alt="" />
LIFT OR BUST! 2001 Sportage EX 4dr 4WD with 300,210 miles & counting .....
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Under Coating the Frame [Re: 69442] #981862 01/21/10 03:00 AM
jaboo5322 Offline
I think somebody wheeled mine before me. Or took it snorkeling. The dealer said they put new parts in front, (from ruined needle bearings and half shaft seals, of course i didn't ask), but i didn't even look underneath. It looked great bodywise. It looked like anywhere that ever had a scrape was rusted bad underneath. <img src="/forums/images/graemlins/barf.gif" alt="" /> Now if you still have a fairly rust free surface, it definately can't hurt to put on some protection.
2001 Sportage, 4" RSG lift, Cragers W/31 10.5 Micky Claws, Warn Manual Hubs, 16 gallon Pro Street Fuel Cell, Custom Snorkel, K&N Filter.
1989 Dodge W250.
Re: Under Coating the Frame [Re: jaboo5322] #981863 01/21/10 03:03 AM
Everet Offline
Remember more weight less mpg's
Re: Under Coating the Frame [Re: Everet] #981864 01/21/10 03:10 AM
jaboo5322 Offline
How thick do you spray it? <img src="/forums/images/graemlins/confused.gif" alt="" />
Ohhhhh. I get it. When the undercariage is rusted away it's lighter. <img src="/forums/images/graemlins/smile.gif" alt="" />
1989 Dodge W250.
Re: Under Coating the Frame [Re: jaboo5322] #981865 01/21/10 03:12 AM
6
69442 Offline
Ya like the Flintstone mobile ... Yaba Daba Doo <img src="/forums/images/graemlins/lol.gif" alt="" />
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Under Coating the Frame [Re: 69442] #981866 01/21/10 03:27 AM
jaboo5322 Offline
I guess you could get excessive with the brush on stuff. That thick wouldn't add any extra protection anyway. How much does three buckets weigh. Make it in two. That way you have an excuse to leave anyone you want behind, (in example: inlaws, ya know, for the go green erra). <img src="/forums/images/graemlins/notooth.gif" alt="" />
Or i could use to lose at least a pound or two. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: Under Coating the Frame [Re: 69442] #981867 01/21/10 03:54 AM
Hydra747 Offline OP
What do you mean?
Re: Under Coating the Frame [Re: Hydra747] #981868 01/21/10 04:06 AM
6
69442 Offline
Undercoating can do two things for you, #1 it protects against corrosion if applied correctly.
#2 when applied to the underside of the floor it helps reduce road noise like a sound deadner.
____o_o
l_l_l\___\___
l----[o]==[o]
l----==[--]==
()_)()_)--()_)
Re: Under Coating the Frame [Re: 69442] #981869 01/21/10 04:35 AM
Hydra747 Offline OP
Thanks 69444 <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.006s) Memory: 0.6421 MB (Peak: 0.7642 MB) Data Comp: Off Server Time: 2026-10-21 22:06:11 UTC
