Twitchy Ignition, not the starter?
#982360
01/24/10 02:11 AM
Gentlemen: So I had a starter motor replaced on my Gen1 1990 Montero two months ago by a reputable mechanic. Since then, the ignition often does not turn over the starter motor when I try to start the truck. Turn the key and nada, zero. It has however, always turned over after 3-4 tries. After looking at the underside of the starter motor, it seemed like the wire from the ignition was poorly connected to the starter - a loose spade fitting. I relaced the fitting, it's plenty tight enough now to always make contact. Anybody got any ideas where I should go from here? Could this be a faulty starter, or a problem with the ignition in the steering column? Problem started AFTER I had the new starter installed.
Thanks! RockDoc
1990 SWB Montero, 3.0l auto, ARB lockers, OME suspension, 32' BFG AT's, PIAA light upgrade.
Re: Twitchy Ignition, not the starter?
[Re: RockDoc]
#982361
01/24/10 02:49 AM
Search for info on the inhibitor switch. Also know as the neutral safety switch. Clean that thing and go from there.
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
[Re: motero]
#982362
01/24/10 02:52 AM
Clean your battery posts and cable really good -- especially if the dash indicator lights are weak and/or the voltmeter isn't registering properly.
Eric W.
[Re: 89IsMine]
#982363
01/24/10 02:59 AM
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: RockDoc]
#982364
01/24/10 06:25 AM
If you're positive that this issue started after the starter was replaced, then logic says you got a less than 100% unit. After it clicks and doesn't spin the first time, crawl under and tap on the starter with a hammer while a helper turns and holds the key in the start position for about a 5 count. Do not strike very hard as gear reduction starters don't like the magnet being beaten up. If it turns over after a tap or two, then replace the starter.
Also, it's a good idea to replace the electrical portion of the ignition switch, especially if it's never been done and the part is original. It's a prime culprit for voltage drops which lead to sluggish starts and other weird issues. It's relatively inexpensive and an aftermarket part will work fine.
[Re: motero]
#982365
01/24/10 10:39 PM
Motero had the same thing on mine. Cleaned it up and tada, works everytime.
[Re: RockDoc]
#982366
01/25/10 12:26 AM
I had the same issue on my raider after replacing the starter. It was a loose spade connector on the starter, replaced it and it hasn't happened again.
Eric 89 Raider V6, 35s, 5sp, welded rear, 8k winch 89 Raider 2.6 going on 84 4runner frame
[Re: SandRaider]
#982367
01/25/10 02:41 AM
I had the same issue on my raider after replacing the starter. It was a loose spade connector on the starter, replaced it and it hasn't happened again. Ditto... On mine the voltage checked out fine at the tip with a voltage meter but I guess some of the wires had come disconnected.
88 Raider- sitting on a full size Chevy frame with 35.5x11.50x16 Dyna Torque II tractors 89 Montero- stock 2.6 M/T 30-9.50 BFG all terrains on American Racing Wheels 99 2500 Ram- 285-75-16 Uniroyal all terrains,straight pipes with no cat (yes its loud)
