project #982614 01/26/10 11:01 PM
burythebeast Offline OP
well thanks to fasteddy i got the 2.6 in time. got it to fire, start and run for a second but died and wont start again. the truck has been setting in a field for a few years and the mice got to the spiderweb of vac lines on the carb. hopin they didnt find the wires tasty... back to head scratching! <img src="/forums/images/graemlins/scared.gif" alt="" />
'96 Jeep XJ
'65 Jeep CJ5
'87 Dodge Raider
'79 Plymouth Trailduster (Ramcharger)
Re: project [Re: burythebeast] #982615 01/27/10 02:51 AM
...the spiderweb of vac lines on the carb. hopin they didnt find the wires tasty... back to head scratching! <img src="/forums/images/graemlins/scared.gif" alt="" />
I'd check both the vacuum lines (lots to go wrong due to age).
May as well check the wires (ignition related wires) but beyond that I'm not sure that electrics will play a big role in this engine running since it's not really an ecu controlled engine. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: project [Re: off-roader] #982616 01/27/10 05:13 AM
The 87 is very much ECU controlled. That's what makes the carb such a Rube Goldberg contraption. Temp sensors, I think a TPS, all the vac lines of course, etc., etc. It's called a Feedback Carburator for a reason.
Mice are very, very evil little creatures. <img src="/forums/images/graemlins/rodent.gif" alt="" />
Re: project [Re: MontyMcV] #982617 01/27/10 07:10 AM
My bad. It is ecu controlled. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: project [Re: off-roader] #982618 01/27/10 03:04 PM
Hey Ray, it was late when I posted, and after a long coupld days at work. Rereading it now, it may sound a little snooty. Didn't mean it that way... <img src="/forums/images/graemlins/ignore.gif" alt="" />
Re: project [Re: MontyMcV] #982619 01/27/10 06:57 PM
Naw, no worries. I was wrong about that. Learn something new every day.
FWIW, I even downloaded & checked the FSM <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
You're right and I was wrong. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: project [Re: off-roader] #982620 01/28/10 10:01 PM
well i figured out the fuel pump isnt working. so i'm replacing that in a minute and see what happens.. $45 through napa! then we replace vac lines one by one..fun fun!
'96 Jeep XJ
'65 Jeep CJ5
'87 Dodge Raider
Re: project [Re: burythebeast] #982621 02/02/10 11:40 PM
well the raider fired up today after we got the spacer for the fuel pump in. now we figure out what to do with the hazard switch. <img src="/forums/images/graemlins/kewl.gif" alt="" />
'96 Jeep XJ
'65 Jeep CJ5
'87 Dodge Raider
Re: project [Re: burythebeast] #982622 02/03/10 02:41 AM
hazy_daze Offline
You could try disassembling it and cleaning the guts. Watch out for the little springs, though get lost easily and without them the switch is useless. You can find these switches used on here and on fleabay.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6308 MB (Peak: 0.7352 MB) Data Comp: Off Server Time: 2026-07-09 16:46:19 UTC
