Replacing DOHC 3.5 with SOHC 3.5 in 95 SR
#983049
01/29/10 06:38 AM
My 95 SR is pushing 200k and just snapped the crank pully bolt, which is patched up but the crank is probably shot. Since they only built the DOHC for a few years they are hard to find. I was wondering if the newer 3.5 would bolt in or is it completely different?
Re: Replacing DOHC 3.5 with SOHC 3.5 in 95 SR
[Re: monster_max]
#983050
01/29/10 09:03 AM
Wiring Harness, ECU and probably a few other things will have to be swapped. Best to buy a totaled doner vehicle with a good engine & possibly tranny to swap.
[Re: monster_max]
#983051
01/29/10 09:16 AM
I believe the cranks are the same between the SOHC and DOHC... I would just rebuild your DOHC with a new crank at most. If you replace the timing belt on time your fine with the current setup.
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#983052
01/29/10 01:57 PM
No don't do it!!!! (unless you want to trade me motors)
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: MBrannon]
#983053
01/29/10 05:52 PM
Thanks for all the input, my local engine rebuilder wants $3000 to rebuild my motor without replacing the crank. I just passed up a 88k motor on ebay for @1400, now the only one there is like $2500. I'm finding SOHC for around $500. I love my Montero but I can't see putting thousands into a 15 year old truck with 200k. Theres one at the Pick n Pull with 160k that has an abondoned vehicle sticker on the windshield with the complete motor I'm tempted to grab but thats a gamble. As long as my crank pully bolt holds my motor runs great, I was just wondering if the SOHC was a bolt in.
[Re: monster_max]
#983054
01/29/10 07:05 PM
Can you pull the block and reinstall yourself? You'd save tons on the $3k that way.
[Re: MontyMcV]
#983055
01/29/10 09:53 PM
The $3000 was with me pulling the motor.
[Re: monster_max]
#983056
01/29/10 11:07 PM
That sounds pretty high to me. I'd wait and see what others who have done it say about a reasonable cost. Maybe you need to take it to someone else...?
[Re: MontyMcV]
#983057
01/30/10 02:51 AM
3.5 DOHC reman when I last check is 3500 w/o core.
--keRby
Ad Inexplorta
[Re: 1986powerram50]
#983058
01/30/10 05:16 AM
Wow, shows what I know... <img src="/forums/images/graemlins/zombie.gif" alt="" />
