Page 1 of 5 1 2 3 4 5
Raider 87 shifting to 5th gear doesn't change RPM #983163 01/30/10 03:35 AM
ricardus Offline OP
Hi
My name is Ricardo, i recently acquired a 1987 Dodge Raider, 4 cylinders, 2.6 Motor, 5 speed manual transmission. The car is all ok, but i noticed when shifting from 4th speed to 5th the RPM doesn't get lowered. I can tell this from the noise of the motor reving up when i shifth to 5th, its like if 5th gear is just another 4th. Last day i drove another Raider of the same specs of mine, and i noticed the gear shifting, though it was a little change, it was noticeable. I just searched the forum but i got entries on issues on automatic transmissions (overdrives) I'm quite unexperienced on this stuff, and i hope you guys could give me some advice, i like my Raider very much but running at 50 mph with the RPM hitting 3600 its tiring and no-fuel-efficient.
Thank you in advance.
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: ricardus] #983164 01/30/10 04:31 AM
Hi
Welcome Ricardo,
Let me get this straight... you have a 5 speed Manual that doesn't change rpm when you shift into 5th? I'm far from an expert on this but I'm not sure that's physically possible unless a prior owner changed the drive gears in the transmission. <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: off-roader] #983165 01/30/10 04:47 AM
0778drz110 Offline
hmm... my calculations with: stock tires, 3600rpm, 50mph, equals 3rd gear....You have no 4th or 5th gear??or what?
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: 0778drz110] #983166 01/30/10 05:02 AM
Kevin C Offline
Stuck in low range?
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: Kevin C] #983167 01/30/10 05:26 AM
Intersting thought. How fast does the speedo read in 1st before you really have to shift?
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: 0778drz110] #983168 01/30/10 06:44 AM
ricardus Offline OP
Thank you all of you for your answers
I seems i don't have 5th gear, i'm at 40-45 mph and when i shift to 5th is identical to the 4th gear, so no RPM change,
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: MontyMcV] #983169 01/30/10 07:09 AM
ricardus Offline OP
MontyMcV : I must shift at very low speed, at 13 mph i think, at that point the RPM is hitting 2000 - 2300 .
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: ricardus] #983170 01/30/10 07:10 AM
You may be in Low Range (4wd low) versus 4wd high or 2wd high.
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: off-roader] #983171 01/30/10 07:21 AM
ricardus Offline OP
The gearshift is in 2wd, i know 4wd low is even slower to increase power and 4wd high has wider range. I mean, the 4wd is disabled. Maybe i'm wrong with the precise speed i told you, but i know it is very low speed.
As for the first thing you told me, the prior owner changing the drive gear, i think it is possible the re arrange it to the original configuration, acquiring an original 5th drive gear? or maybe i'm wrong?
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: ricardus] #983172 01/30/10 09:16 AM
LandRaider Offline
the difference between 4th, and 5th is not that big.
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6420 MB (Peak: 0.7676 MB) Data Comp: Off Server Time: 2026-07-15 14:15:29 UTC
