Page 4 of 5 1 2 3 4 5
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: Kevin C] #983193 02/03/10 03:42 AM
ricardus Offline OP
Thank you guys, never had such good attention in other sites
But well, this just sucks, seems likely i'll need to spend some money in a new tranny, or maybe it can be repaired/modified/something?.
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: ricardus] #983194 02/03/10 03:52 AM
TrailRaider Offline
I dont have actual numbers and cannot get them (trans is sitting on a bench at work pending a rebuild) But my 4th and 5th gear RPM's are VERY close. Hardly noticable at all, ever. My truck has 235ish thousand miles on it, but even 10 years ago with ~150k it was the same way when it was my brothers. If you have larger than stock tires, that puts extra strain on the clutch and may be causing it to slip in 5th gear just enough to negate the OD funtion of 5th gear. Just a thought.
'89 Raider V6 auto.
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: off-roader] #983195 02/03/10 04:25 AM
0778drz110 Offline
Can anyone with a 2.6 manual duplicate the 2500 rpm speed test and report back your results?
i'm getting about about 55 on the speedometer with 31" tires, I get about 45-50mph at 2100rpm
about 3200rpm at 70-75mph
at 35mph i do about 1500-1750rpm
clutch in at about 25mph or so
all in 5th gear
<img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: TrailRaider] #983196 02/03/10 04:44 AM
Kevin C Offline
I don't have actual numbers and cannot get them (trans is sitting on a bench at work pending a rebuild) But my 4th and 5th gear RPM's are VERY close. Hardly noticeable at all, ever. My truck has 235ish thousand miles on it, but even 10 years ago with ~150k it was the same way when it was my brothers. If you have larger than stock tires, that puts extra strain on the clutch and may be causing it to slip in 5th gear just enough to negate the OD function of 5th gear. Just a thought.
To make it easy....
Here are the gear ratios:
1st = 3.967
2nd = 2.136
3rd = 1.36
4th = 1
5th = 0.856
And...
3200 RPM = to 60 MPH Fourth gear
3200 RPM = 71 MPH in fifth
Assuming 29" tires. Although tire size wont alter the speedeo to tach ratio unless you change the speedo gear in the tranny.
Basically, 35's will get you the same reading.
Kevin
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: Kevin C] #983197 02/03/10 08:33 PM
ricardus Offline OP
With all the above information, this question could sound stupid due my unexperience, it is possible to give 5th gear a wider ratio ?
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: ricardus] #983198 02/03/10 08:39 PM
LandRaider Offline
4th and 5th are so close together that you can't tell a difference I am betting
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: LandRaider] #983199 02/04/10 01:14 AM
With my noisy, tin-can, no windows turbo SWB, there are definitely times when I reach down to pull it from 4th to 5th, only to find I am already in 5th.
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: MontyMcV] #983200 02/04/10 01:58 AM
0778drz110 Offline
huh, I always push mine from 4th to 5th....
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: 0778drz110] #983201 02/04/10 02:26 AM
I used to slide mine.
Re: Raider 87 shifting to 5th gear doesn't change RPM [Re: JohnnyBfromPeoria] #983202 02/04/10 04:28 AM
What if a 4 speed got replaced for the 5spd, but with the 5spd shifter? The fork shifts nothing, so it stays in 4th...
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.010s) Memory: 0.6419 MB (Peak: 0.7667 MB) Data Comp: Off Server Time: 2026-07-15 12:47:57 UTC
