33 x 12.50's won't fit due to weird mudflaps #983238 01/30/10 05:06 PM
87_Montero Offline OP
IÆm fitting 33 x 12.50s on a 1989 3.0 liter 5 speed. This Raider has mud flaps on the front bumper. At first I thought these were aftermarket mud flaps.
My first thought was to drill out the bolts holding the mud flaps and their mounting hardware onto the bumper.
But the mudflap mounting brackets are an integral part of the bumper! In this photo you can see that the mudflaps are mounted on a heavy-duty bar (thickness 3/16th, breadth 1 3/4 inches) that is seamlessly integrated into the bumper. There are no bolts or even the seam of a weld between this bar and the bumper.
This is the only Monty IÆve ever seen with a bumper & mudflaps like this. Is this something worth saving?
I'll try to bend the bar out a couple of inches. If this doesn't work then I'll have to cut it back about 2 inches.
Thoughts or ideas?
DDs:
Projects: 86 Ram50
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: 87_Montero] #983239 01/30/10 05:19 PM
I don't believe those are stock.. I've never seen that as an available part in CAPS anyway. Are they formed in a special shape or simply bent to match the curve of the body/bumper?
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: off-roader] #983240 01/30/10 05:38 PM
87monty Offline
I would Do away with them, I have 33x12.50's With the stock rear flap and they fit good. May have to crank up the torsion bars a little to give you added room <img src="/forums/images/graemlins/kewl.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: 87monty] #983241 01/30/10 07:59 PM
89montero Offline
I'm almost positive they aren't stock. I've never seen them before and they're pretty ugly for something that came factory. Wouldn't they have used a similar design as the rear flaps?
Looks to me like someone just bent a piece of flat bar and welded it to the bumper.
Either way there's no need for them so I'd just dump it.
1989 Montero 4dr V6 3.0l
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: 87monty] #983242 01/30/10 08:08 PM
Those flaps are not stock. The hardware is USS coarse thread. I think I see welding flash, or evidence of, in the first picture along the bottom side of the bumper. I'd just take them off, too.
When I had my first set of 33s and was test fitting, I snapped these photos:
I trimmed the bumper end and the splash guard inside the front wheel well. After my second set, I found a nice place to flex the chassis up and shot this photo:
The tires did not rub, no suspension tweaking, just the minor trimming. The first photos have 10 inch wide rims, the last has 8's in the front and 10's in the rear. The different rim width evened out the tire exposed beyond the fender.
R-
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: 87_Montero] #983243 01/31/10 02:02 PM
MBrannon Offline
As said before, those are not stock. Mitsu would not have used crappy hardware like that...besides other things.
Just yank em! <img src="/forums/images/graemlins/smile.gif" alt="" />
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: rxinhed] #983244 02/02/10 04:58 AM
It turned out to be easy to bend mudflap bracket outward, so I've done that first.
In addition to dealing with the mudflap bracket, the bumper guards needed trimming, and I had to push out the front of the wheel well to allow clearance of the tires when turned fully inward.
Here's the fit on the left side . . .
And the fit on the right side . . .
On the right side, the gap between the bumper and the mudflap is not as obvious as it looks in this photo.
Here's what the truck looks like wearing its new 33 x 12.50's . . .
This also provides a good look at the mudflaps . . .
DDs:
Projects: 86 Ram50
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: 89montero] #983245 02/02/10 05:18 AM
bodyswapped8789 Offline
Do you plan on mudding in reverse? Plus dont you think they will
get in the way wheeling?
89 V6 manual trans Dodge Raider frame 87 cold weather pkg 2" body lift, Soft 8's wraped in BFG km2 33x10.5x15, JDM Pajero yellow Bosch fogs. Yackama basket. Duel bouncies gen II rear springs,gen II ft brakes,master and booster.
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: bodyswapped8789] #983246 02/02/10 05:41 AM
StockRaider Offline
just take those bolts out and remove those abomination flaps. I ended up buzz cutting all flaps from my Raider. <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 33 x 12.50's won't fit due to weird mudflaps [Re: bodyswapped8789] #983247 02/02/10 06:26 AM
I can't figure out why someone put these on this truck in the first place!
Can you make any sense of this?
Do you think this intended to be functional or stylish?
DDs:
Projects: 86 Ram50
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6416 MB (Peak: 0.7679 MB) Data Comp: Off Server Time: 2026-10-26 16:52:36 UTC
