80 2.8L rebuilt engine woes
#983346
01/31/10 11:52 PM
had a shop reman a 2.8 for me. had them also install a "RV" cam for more power. Reinstalled engine and have been chasing demons every since. Found a couple of vac and one exhaust leak - fixed them. Checked timing, throttle body, ECU and everthing else I could think of. Was getting gas and spark to all cyls. Runs rough and had NO power. Finally ran a bore scope down pass side cyls and they looked like they are brand new with no signs of combustion. Wondering if the cam may somehow be at fault? How can I verify this?
Re: 80 2.8L rebuilt engine woes
[Re: 89troop]
#983347
02/01/10 05:19 AM
If one bank of cyl's is running with the RV cam, it's highly unlikely for the cam to be the cause of the other bank's suspected inoperability.
Have you checked compression on all cylinders?
If the valve lash is set too tight, these motors will not run. Low compression readings in several cylinders would make me suspect lash problems rather than mechanical failures in a new motor. You could always try backing off the preload 1/2-3/4 turn on each rocker arm locknut on the pssgr's side valves and see what happens.
Also, have you checked & double-checked the firing order?
It's 1-2-3-4-5-6 clockwise around the cap, with 1-3-5 on the pssgr side and 2-4-6 on the driver's side, 1 and 2 being at the front. Another thing that's very easy to get swapped and real hard to tell what's wrong.
HTH & let us know what you find.
'90 Troop 3.4 LS '89 Troop RS (Has Valve Issues, needs Counseling) HI, I'm Ed and I'm a Trooper-holic! Keep On Troopin'......
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5893 MB (Peak: 0.6375 MB) Data Comp: Off Server Time: 2026-05-29 23:52:02 UTCValid HTML 5 and Valid CSS
