02 axiom wont start #983444 02/02/10 12:57 AM
94rodeo Offline OP
have an 02 axiom that will start sometimes and then it will not start for a day or so. Any ideas?
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: 02 axiom wont start [Re: 94rodeo] #983445 02/02/10 05:29 PM
94rodeo Offline OP
when you start driving it, it will have the check trans light and cruise control lights come on and it will lose power and die. then it will not start for a day or so.
94 Rodeo
Re: 02 axiom wont start [Re: 94rodeo] #983446 02/02/10 05:30 PM
94rodeo Offline OP
there is a check engine light on, but whenever a scan tool is hooked up it says no connection.
94 Rodeo
Re: 02 axiom wont start [Re: 94rodeo] #983447 02/04/10 08:47 PM
94rodeo Offline OP
man this place is dead
94 Rodeo
Re: 02 axiom wont start [Re: 94rodeo] #983448 02/05/10 03:15 AM
Jim_Paget Offline
A big part of the problem, Troy, is that there are very few people with the variant of the engine that you have. There is a term for that form of injection, but I can't remember what it is, but it was only used on the last year or so of the Isuzus.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 02 axiom wont start [Re: Jim_Paget] #983449 02/09/10 01:23 AM
holger Offline
Actually, the direct injection engine appeared only in 2004. The Axiom 02 engine is pretty conventional - I suppose this is the same engine (with possibly minor variations) as on 2002 Trooper. The transmission and the transfer case are the same as on the Trooper, too.
Oleg
Deceased Rodeo'02 4WD.
Re: 02 axiom wont start [Re: holger] #983450 02/11/10 05:50 AM
V
vovkus Offline
Troy,
if you have 2002, then it is not DI engine.
First, check connectors on the PCM (Computer). Possible some moister in the connector. Disconnect battery, disconnect two connectors from the PCM and apply electrical connector cleaner. After it dry, connect back and try.
2001 Trooper LS 3" lift,no more Rancho 9000RX,
no more 4L30E transmission,
ProComp 8" 130W driving lights,
Surco roof rack (modified),
110V power outlet, Viair 380C compressor,
CB/FRS/GPRS/HF/VHF/UHF Radio, 285/75/16 BFG AT/KO.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6206 MB (Peak: 0.6951 MB) Data Comp: Off Server Time: 2026-10-22 07:41:42 UTC
