Longer UCA bolts for Gen1 #983571 02/02/10 04:55 PM
MarcDurant Offline OP
I know someone must have extras kicking around. I need longer UCA mounting bolts for my Gen1 so I can add enough shims to get the camber right. I believe the stock size is 12x1.25x55mm grade 10.9, and the recommended longer bolt is the same size except 70mm long?
89 Raider V6 manual
89 Montero 2-door Coupe "Super Legera"
91 Montero 4-door manual (Mint! Sunroof, cruise, power everything, BOUGHT FROM THE ORIGINAL OWNER!)
Re: Longer UCA bolts for Gen1 [Re: MarcDurant] #983572 02/02/10 06:57 PM
hazy_daze Offline
I drilled mine out to 1/2" and used grade 8 bolts when I did the GenII UCA's. Much easier to find and cheaper.
Re: Longer UCA bolts for Gen1 [Re: hazy_daze] #983573 02/02/10 07:59 PM
Chief Offline
X2
'89 Raider V6, AT, SAS'ed, Dana 44 front & rear, 5:38 gears, NP 231 T-case.
'97 Montero SR, cold weather package, 4.90 R&P, BATTLEZ suspension w/ 2" lift, JAOS grill guard & under body protection, custom rock sliders.
Re: Longer UCA bolts for Gen1 [Re: Chief] #983574 02/03/10 04:47 AM
haztoys Offline
X2
Thats what I've done over the years ...Have you priced a 12mm by 70mm metric bolt..???? ... In my part of the world there not cheap ... <img src="/forums/images/graemlins/scared.gif" alt="" />...
David
Hazardous Toys inc
Re: Longer UCA bolts for Gen1 [Re: haztoys] #983575 02/03/10 02:42 PM
For a bolt, they're expensive, but in the context of auto parts, they're not that bad. I'm seeing anywhere from $3-$8/each, but having trouble finding the finer thread bolts (12x1.25 or even 12x1.50). I found an old post from FrankR saying that he bought a box of them, I was hoping he'd have some left.
89 Raider V6 manual
Re: Longer UCA bolts for Gen1 [Re: MarcDurant] #983576 02/03/10 05:24 PM
Just got a quote from MetricMMC.com.
Price for 12mm x 1.25 x 70mm is $2.74/each plus shipping.
Grade 10.9
Minimum order is $25 or 10 bolts.
Anyone else want some?
89 Raider V6 manual
Re: Longer UCA bolts for Gen1 [Re: MarcDurant] #983577 02/07/10 07:45 AM
Oyaji_Jon Offline
I'll take a set. How many are required? I haven't gotten into the front end on my rig yet but have a set of UCAs in the garage.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Longer UCA bolts for Gen1 [Re: Oyaji_Jon] #983578 02/07/10 09:05 PM
hazy_daze Offline
You'll need 4 of them Jon. But, as an alternative, you can get 1/2" bolts in the longer length for literally pennies apiece. All that's required to make them fit is a 15/32" or 19/64" drill bit, whichever you choose to ensure there's no slop. And you'll find plenty of uses for that bit. I have.
Not trying to talk you out of it. Jus sayin... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Longer UCA bolts for Gen1 [Re: hazy_daze] #983579 02/11/10 09:46 PM
Oyaji_Jon Offline
As always, thanks for the info, Larry. I'll cross that road when (if) I come to it.
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: Longer UCA bolts for Gen1 [Re: Oyaji_Jon] #983580 02/11/10 10:32 PM
hazy_daze Offline
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6389 MB (Peak: 0.7624 MB) Data Comp: Off Server Time: 2026-06-10 01:33:30 UTC
