Re: Looking for a Montero. Which year? [Re: JohnnyBfromPeoria] #983676 02/02/10 10:03 PM
Montero7081 Offline OP
Of course anything is possible with the right amount of money, time, tools and energy. I should have worded that differently. Agree 100%
All V-6's are fuel injected. Good to know. Thanks.
Re: Looking for a Montero. Which year? [Re: Montero7081] #983677 02/02/10 10:14 PM
Curious what your 1996 looks like with 35's?
See the FAQ thread which is the 2nd post of this forum.
In that post you'll find several build up threads. Look for mine there. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Looking for a Montero. Which year? [Re: off-roader] #983678 02/04/10 06:55 PM
1994-1997 SR has the locker from what I hear. But, those years have the 3.5L?
Re: Looking for a Montero. Which year? [Re: Montero7081] #983679 02/04/10 07:23 PM
3.5L, 24 valve, 4 cam. The "hot" set-up. Be aware, that engine recommends premium fuel.
Re: Looking for a Montero. Which year? [Re: JohnnyBfromPeoria] #983680 02/04/10 07:39 PM
I usually run 91 anyways. The 4x4 rigs I have/had are only offroad. Not DD. So, that's ok. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Looking for a Montero. Which year? [Re: JohnnyBfromPeoria] #983681 02/04/10 07:41 PM
Dylan Offline
...Be aware, that engine recommends premium fuel.
That is interesting. Since mine didn't have any premium warning stickers anywhere, I did not know that. I didn't bother looking at the manual either, but after a few thousand miles with regular 87 it seems fine. It definitely feels more powerful than any of the 3L SOHC's I have test driven too. Now I am going to have to try 91 and see how it feels... if I ever get this damned pulley back on of course...
'95 Montero SR 3.5L, Trail Gear Sliders, Rugged Ridge XHD Front Bumper, 33x12.5 Duratracs, much more in the works....
Re: Looking for a Montero. Which year? [Re: Dylan] #983682 02/04/10 07:45 PM
I didn't notice until I was putting fuel in a couple of days after I got it and saw the label inside the fuel door. "Premium Fuel Recommended."
The knock sensors are good enough to retard the engine's timimg without trouble, but drop some primo in there and it's going to come alive with full advance. I mean, wow.
Get that crank bolt issue fixed and Seafoam it, too. We're talking 5000 lb. rocket ship. Sort of.
Re: Looking for a Montero. Which year? [Re: Montero7081] #983683 02/05/10 12:16 AM
ryany Offline
My understanding is that the 3.5 DOHC came in the SRs from 1994-1997, after that the 3.5 SOHC was used. I may have the years wrong but I'm sure someone will correct me if they are.
The engine will run on regular unleaded - premium is only recommended, not required. I usually run mid-grade around town but can definitely feel the difference in power when I run a tank of premium through it. I get about 1/2 mpg better mileage with premium also, so it's almost worth it.
The 3.5 DOHC has a known issue with the variable intake butterfly valves working themselves loose & getting swallowed by the engine. The butterfly shaft itself is prone to wearing out the bushings and creating a vacuum leak - it's probably this looseness that allows vibrations to work the butterfly screws loose. Some people have taken the lower intake plenum off, removed the shaft and plugged the holes rather than spend the money to replace it when it goes bad, and usually report no noticeable difference in power. In my opinion that's removing a piece of an engineered system that Mitsubishi spent a lot of time designing. If there wasn't an advantage to it, I'm pretty sure they wouldn't have put it on the engine in the first place. It's kind of like removing your fuel injection system because you've got a couple of bad injectors, and replacing it with a carburetor because it's cheaper & easier to work on.
Anyway, if you're looking at a 3.5 DOHC make sure you check for any play in that shaft, along with verifying the age of the timing belt. The timing belt is do-able but challenging for an average home mechanic due to the complexity of the engine. If the vehicle you're looking at needs it done make sure you include that in your negotiations because it's not a quick & easy job.
The 3.5 DOHC is a complicated engine, but is very strong & reliable. Mine hasn't needed anything except maintenance under the hood for over 50k miles now. My oil pressure gauge has stopped working but I'm sure that's due to the salt water drowning the truck endured about a year ago.
Oh yeah - almost forgot, make sure you check to see if the crankshaft pulley bolt has been replaced with the updated version. Mitsubishi updated the design and the torque setting for it - several people here can attest to the issues that occur if it's not updated. <img src="/forums/images/graemlins/frown.gif" alt="" /> Search this forum for info on it - it's been covered numerous times with pictures and part numbers.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6316 MB (Peak: 0.7473 MB) Data Comp: Off Server Time: 2026-06-20 18:04:59 UTC
