95 Gen II LS rear end question #983847 02/04/10 02:04 AM
bigroxydog Offline OP
Just purhased a 95 LS and noticed in the center counsel a button that states A/T Mode what does that button do? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: 95 Gen II LS rear end question [Re: bigroxydog] #983848 02/04/10 02:22 AM
Normal operation in the center position.
Power mode (lights up in the dash center, in green), holds shifts to a higher RPM, the more you press the gas, the higher the shift point. Also downshifts earlier, I believe.
Hold mode (again, lights up green in the center of the dash), starts truck from a stop in 2nd gear. Useful in slippery/snow conditions. All other functions normal.
Re: 95 Gen II LS rear end question [Re: JohnnyBfromPeoria] #983849 02/04/10 02:35 AM
Did the LS only come with the Limited slip or do they have a locker rearend. How do I tell what I have? Vin number, tag on rearend, no Orange sticker on the door pannel like I have on my 88 GEN I., button on dash?
Re: 95 Gen II LS rear end question [Re: bigroxydog] #983850 02/04/10 03:13 AM
ryany Offline
If you have the locking rear axle you will have a switch on the dash below the left side of your stereo labeled "R/D Lock".
95 Montero SR
Re: 95 Gen II LS rear end question [Re: ryany] #983851 02/04/10 03:36 AM
And if it doesn't have the locker, is it an LSD?
Re: 95 Gen II LS rear end question [Re: JohnnyBfromPeoria] #983852 02/04/10 06:01 AM
The 95 LS is open/open.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6100 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-07 11:31:07 UTC
