Leveling help #984469 02/07/10 04:16 PM
dldjj5 Offline OP
Hi
New to the board, I have a 2002 Toyota Tacoma prerunner with a Tuffcountry 5 inch lift. My front end sits about 1 inch lower, Can I use a spacer to level this out ? Not sure if you could mix kits like that. I don't do any offroading mainly just street use. Thanks in advance
Re: Leveling help [Re: dldjj5] #984470 02/08/10 08:24 AM
humanoid Offline
How is the front currently lifted?
Re: Leveling help [Re: dldjj5] #984471 02/17/10 06:35 AM
W
whirlibird Offline
Hi
If it were me, I would leave it alone. For ~1", any small load in the back will level it out. Most trucks I know of do sit a little lower in the front due to the idea that the truck will be loaded and bring it back level or beyond. I actually lifted the back of mine more so that when it has the normal load I haul everyday that it sits slightly above level and more load on occasion keeps it looking good.
If you choose to level it out, be careful in mixing kits. If there ends up an issue, one mfr will blame the other and so on.
'03 Nissan Xterra, 3.3L V6, Auto, Factory Limited Slip rear diff <img src="/forums/images/graemlins/smile.gif" alt="" />
'72 International 1210 3/4-ton flatbed w/ snow plow. Granny low anyone? <img src="/forums/images/graemlins/kewl.gif" alt="" />
'99 Toyota Tacoma X-cab, TRD, 2 1/2" lift, 32x11.50 MTR's on polished AE 058's. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Leveling help [Re: dldjj5] #984472 02/19/10 02:59 AM
F
fstowe Offline
If U used blocks in the rear use a 1'smaller block.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6019 MB (Peak: 0.6575 MB) Data Comp: Off Server Time: 2026-06-17 04:21:33 UTC
