Page 2 of 4 1 2 3 4
Re: The Best Oil? [Re: JohnnyBfromPeoria] #985232 02/12/10 02:21 AM
One more tidbit, I run a NAPA Gold filter. They're closer to my house than a dealer. They made a filtration comment, so I thought I'd add that.
Re: The Best Oil? [Re: JohnnyBfromPeoria] #985233 02/12/10 02:33 AM
blinkerbox Offline OP
Now that's pretty cool. Rotella, eh? So what's the make-up of the NAPA filter?
'91 RS, '93 SR
Re: The Best Oil? [Re: blinkerbox] #985234 02/12/10 02:36 AM
They've got one of the most hilarious faq pages.
'91 RS, '93 SR
Re: The Best Oil? [Re: blinkerbox] #985235 02/12/10 02:57 AM
Bob Is The Oil Guy
More than you ever wanted to know about oil and filters.
The END!
Re: The Best Oil? [Re: JohnnyBfromPeoria] #985236 02/12/10 03:23 AM
mike71800b Offline
Bobs does have lots of good info.
I had a 2f toyota in the shop recently i rebuild for a fellas FJ40 and had isky cams build up and regrind the old cam since good 2f cams are about non existant.
They would only warranty it with brad penn oil.
http://www.bradpennracing.com/
I'd never used it before that build but it is SLICK like i remember oil was when i was a kid, dark so plenty of moly and zddp.
Thought it might be worth a mention
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: The Best Oil? [Re: mike71800b] #985237 02/12/10 05:19 AM
JohnnyBfromPeoria, thanks for all the useful information. When I get a couple more miles on my engine (currently at about 700 miles), I think I'll send in a sample to be analyzed.
'91 RS, '93 SR
Re: The Best Oil? [Re: blinkerbox] #985238 02/12/10 08:51 AM
Thumbs up, M'brother.
Re: The Best Oil? [Re: blinkerbox] #985239 02/12/10 12:32 PM
P
pcc Offline
He said that Mobil 1 was overrated and had ôtoo much plasticö.
Re: The Best Oil? [Re: pcc] #985240 02/12/10 03:12 PM
JAVYPRO Offline
Here is what I use:
1988 Monty:
Castrol 10w40
Changed every 7k miles
Fram filter
Transmission oil:
Lucas oil Fully Synthetic
2001 Monty:
Mobil 1 Synthetic 10w30 Extended Performance
Changed every 15k miles
Mitsu filter
Transmission oil:
Mitsubishi
2004 Triumph Speed Triple SE
Mobil 1 Synthetic specialy formulated for Triumph
Changed every 6K miles
Tripumh filter
Transmission oil:
N/A
1974 Mazda Rx3
Castrol 20w50
Changed every 3k miles
Mazda filter
Transmission oil:
Castrol 90
I am curious about Royal Purple but have never give it a try. As for the filter I amd pro using the factory filter so that brings a question to mind; I remember reading somewhere that Mitsubishi uses the same oil filter on most of its models, any word on that?
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: The Best Oil? [Re: JAVYPRO] #985241 02/12/10 03:52 PM
What I remember about the TP filter is that the oil passes from end to end of the roll, with an extemely low pass size, as all the particulate has to go past a long distance lined with lots of little particle grabbing fibers. This is preferable to a short pass thru a membrane filter. Surface area is lower than a pleated filter, so more than one unit may be required.
Page 2 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.007s) Memory: 0.6397 MB (Peak: 0.7644 MB) Data Comp: Off Server Time: 2026-10-21 17:07:52 UTC
