Cluch is sticking on my 95 4runner? #985559 02/15/10 07:34 PM
4
4runTAZ Offline OP
I just replaced it about a year ago and was woundering if anyone had a solution? 1995 4runner 35x12.50 3.0 4x4
Re: Cluch is sticking on my 95 4runner? [Re: 4runTAZ] #985560 02/16/10 01:17 AM
W
whitetoy Offline
2 suggestions:
1 - Call the shop that did the work
2 - run smaller tires
Rick
1984 4Runner
Re: Cluch is sticking on my 95 4runner? [Re: 4runTAZ] #985561 02/16/10 03:00 AM
kewlynx Offline
Check to make sure your clutch bracket isn't cracked; that'll cause some sticking; not uncommon, esp if you're heavy footed with the clutch.
then:
http://www.4x4wire.com/toyota/maintenance/clutchmaintenance/
then read this:
http://www.4runners.org/writeups/clutchbush/index.html
Be sure you read the yotatech thread too.
Smaller tires, what?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Cluch is sticking on my 95 4runner? [Re: 4runTAZ] #985562 02/16/10 06:31 AM
Adam F Offline
What do you mean by sticking clutch? You press the pedal down, and it sticks to the floor? If so, its either your clutch master or slave cylinder. Go ahead and rebuild/replace BOTH. They are cheap.
97 4R, stock, daily driver
Re: Cluch is sticking on my 95 4runner? [Re: Adam F] #985563 02/18/10 12:25 AM
4
4runTAZ Offline OP
When ever i push in the cluch it only sticks sometimes but seems like its happening more and more cause im have to pop it back up with my foot. I have 4.56 gears and im thinking i might just have to get 5.29 if this is gona keep on happening.
Re: Cluch is sticking on my 95 4runner? [Re: 4runTAZ] #985564 02/18/10 02:28 AM
kewlynx Offline
That won't fix it. Just go get the gears anyway! <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
**ubi apis- ibi salus**
Re: Cluch is sticking on my 95 4runner? [Re: 4runTAZ] #985565 02/18/10 04:45 AM
Adam F Offline
Gears have absolutely nothing to do with it. Either do tires <img src="/forums/images/graemlins/confused.gif" alt="" />
Your clutch hydraulics are bad. I had the exact same problem. I rebuilt my clutch master cylinder. Didn't fix it. I then replaced my clutch slave cylinder and problem solved.
Re: Cluch is sticking on my 95 4runner? [Re: Adam F] #985566 02/18/10 07:00 AM
4
4runTAZ Offline OP
Ill get back at ya when i do it this weekend and see if anything has changed and if not ima just have to wait about a month to get gears from my bro, hes doing a solid axle swap on his yota.
Re: Cluch is sticking on my 95 4runner? [Re: 4runTAZ] #985567 02/19/10 12:57 AM
Adam F Offline
You want 5.29 gears with 35" tires.
A new master/slave will fix your problem, trust me.
Re: Cluch is sticking on my 95 4runner? [Re: Adam F] #985568 02/23/10 05:43 PM
G
Greg_Canada Offline
I'm having the same problem
My clutch MC is aisin and slave is autozone both at 2 years old. Think i should switch back to an aisin slave?
89 4Runner
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6404 MB (Peak: 0.7602 MB) Data Comp: Off Server Time: 2026-07-09 16:51:18 UTC
